Thread: Opportunity to buy used heater..need advice!
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Hello All,
    I have found a used Hayward H 350(?) that the owner is asking 600 for. Its older but looks to be in good shape. See pic
    Attachment 50866
    It is currently on propane but I would like to switch it to natural gas. Complet newbie at the heater thing so could use some help.
    Do you think it's worth it? My pool is quite small and it would be used sparingly in conjunction with solar.
    Any advice would be appreciated.
    R
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Jun 2012
    western NY
    1,560
    Re: Opportunity to buy used heater..need advice!
    Is it currently hooked up like it appears in the picture? If so how well does it fire up? How does it look inside of it with the covers off? Minor rust is OK but flaking rust is bad. Definitely a lot more heater than you need but will work just fine provided you have sufficient gas supply to run it. Conversion kits can be purchased to convert to Nat gas. Were they really running it indoors like that??????
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Thanks for the reply danpik. Heater was outside it is currently stored in garage. Property owner subdivided property for development so pool had to go. He has pumps, skimmers chemicals etc. for sale.
    Because of the wait time for the gas install could I use a couple of 100 lb LP tanks? I would convert as soon as the install is complete.
    Thanks
    R
    ps0303's Avatar
    Jul 2011
    FL
    3,692
    Take it apart and look at the bypass and see if it is in good shape. That old of a unit I can't imagine it's in good shape. Also, that appears to be a unit with a pilot light. This is out dated and will cost you $$$ even when are not using it as the pilot light will be one.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
