Results 1 to 8 of 8
Thread: How much salt to add to pool? Does pool math do this?
    May 2016
    Toronto
    130
    Hey,
    I am having a SWG installed today. The Zodiac Auqapure EI. I believe the manual says to get the salt to an optimal 4000ppm. What does this mean? How much salt is that?
    I have a 16x34 pool, approx 22,000 gallons.
    How do I use pool math to figure this out? Thanks,
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    Jun 2014
    15,235
    Re: How much salt to add to pool? Does pool math do this?
    Yes, the Poolmath Calculator can help with that. First I enter your pool size (gallons) at the top, then on the salt row, if I enter "0" for (NOW) and 4000 (TARGET) it tells me that equates to 736 pounds.
    Pool School - Water Balance for SWGs
    Pool School - Salt Water Chlorine Generators
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    It''s the last choice in the dropdown for Effects of Adding Chemicals.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Toronto
    130
    Quote Originally Posted by Texas Splash View Post
    736 pounds??? jesus...Very family friendly forum here
    I got that too, just thought it was wrong.
    Also, this is just fresh water from the hose, is there any salt in it already? I have the taylor k-2006, but that cant test salt right?
    Are the aqua pure stripes any good?
    38,507
    I would not assume that your salt level is zero right now. But it is not likely over 500 ppm. I would probably go ahead and add about 3000 ppm and see what that SWG reports after that
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Just an FYI, using the AquaChek strips my salt measured ~1300 ppm without ever having been directly added (at least for the 2 years I have owned).
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Oct 2015
    Katy/Texas
    411
    Does your SWG tell you what the salt level is?
    Test strips are not considered accurate.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Pool Tool's Avatar
    May 2014
    757
    Edit - Post deleted.
