Results 1 to 20 of 20
Thread: Sharkline Matrix 24'x54" DIY install.
    Jul 2010
    Jacksonville, NC
    35
    Finally getting around to installing our pool.
    So far we have dug the hole deepest part being 2' under grade with the low side going down 7".
    16 Ton worth of crusher run for the base.
    Tomorrow will be getting
    18- 4"x8"x16" concrete caps for the posts
    16-pieces of 1" pink foam insulation.
    renting a plate vibrator
    Planning on a 3" base of crusher then leveling blocks on that. Then filling, leveling, tapping more crusher to the top of the blocks. OR should I get the base right and dig out the holes for the blocks? I've been goin back and forth on this in my head for the longest!
    Planning on blackfilling with the excavated dirt as well. 6" french drain on top of the backfill. From what I have read the dirt needs to settle 2 years and wait till a dry week before quickly changing out the liner.
    For now pump and filter will be the intex 2650 gph pump and sand filter.
    Thats all for now.....
    24' X 54" Sharkline Matrix. J-Hook liner.
    2 speed pump, 16" Intex sand filter.
    Jun 2016
    Kansas City MO
    23
    Re: Sharkline Matrix 24'x54" DIY install.
    So a 3" base of fines then 4" more to level with the blocks, 7" total?
    Jul 2010
    Jacksonville, NC
    35
    That's my idea, but am open to other ideas.
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    160
    We used 12 x 12 pavers and flattened about 3 inches of rock dust. When we dug the pavers in almost all sat on dirt. After it was up and filled it rained for about two weeks and darn if that thing didn't move at all. Very happy. We also did the French drain and buried half way...well in the process of.
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    Jun 2016
    Kansas City MO
    23
    my thought is that if you're compacting fines, then I'd use 2" blocks instead of 4". Maybe 2" blocks laid in 4" of fines. 7" seems like a lot, but I guess couldn't hurt (except your back maybe)
    Jul 2010
    Jacksonville, NC
    35
    After a very long, hot weekend we are at this point now. Waiting on the water bonding part now...
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Coming along nicely!
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Jul 2010
    Jacksonville, NC
    35
    Quick question.
    When should I cut the liner for the skimmer and return?
    Jul 2010
    Jacksonville, NC
    35
    AS of now we just put in the liner with the intention of adjusting it. But, does this look normal? or small? The seam that goes evenly on the cove does not even reach it!
    Did they send me a small liner then I need?
    Or do I go forward and stretch it?
    Casey's Avatar
    SW PA
    10,438
    You need to pull that liner to the other side of the pool. You've got too much bunched on one side. And hook up a shop vac n tape the openings off to create a vacuum.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Not sure, but the "waterline" tile mark should probably start out higher up. I believe the liner scratches as it fills. Is it a beaded liner or overlap?
    When my SIL's pool was done, the filled it 3/4 of the way before cutting for the skimmer.
    Jul 2010
    Jacksonville, NC
    35
    Its a overlap...pain in the butt!!!
    Casey's Avatar
    SW PA
    10,438
    Any over lap that I've installed that had a pattern never went in with the border completely level the whole way around because I never dished the bottom of the pools out. I have found that the bottom seam always ran up the wall in one area. Always.
    Jul 2010
    Jacksonville, NC
    35
    Thanks Casey! That is exactly what it did!
    Casey's Avatar
    SW PA
    10,438
    How's it looking?
    Jul 2010
    Jacksonville, NC
    35
    Forgot to update...
    But after fighting the overlap liner a day and a half I bought a J-Hook liner. Took 1 hr to install the J liner! To ANYONE debating on which to buy...J HOOK J HOOK J HOOK....
    SO much easier to install! Have about a foot left to fill. :) Then on to plumbing, deck, etc
    Casey's Avatar
    SW PA
    10,438
    I have a j hook and it was so easy.
    Jul 2010
    Jacksonville, NC
    35
    Yes it was! Hands down the easiest to install.
    Jul 2010
    Jacksonville, NC
    35
    Pool plumbing done!
    And OPEN!
    Those union ball valves....When turned off and disconnected do NOT seal! Thought the did?!
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,438
    Get that ladder out of that pool. It could ruin the liner.
    Other than that, the pool looks great.
