Results 1 to 8 of 8
Thread: Set-up over grass
    Jun 2016
    Lynn, MA
    6
    Set-up over grass
    I have a 15' x 36" Intex Easy Set pool. I was thinking of putting down about 3" of peat moss over the grass, topped off with 8 sheets of R-Tech 1 in. x 4 ft. x 8 ft. Insulation and then a Gorilla pad. Any thoughts on this?
    Intex 15 foot x 36" Easy Set Pool & a Gorilla pad. Holds 2,800 gallons of water at 80% full. Thinking of putting down about 3" of peat moss, topped off with 8 sheets of R-Tech 1 in. x 4 ft. x 8 ft. Insulation and pad. Have a Intex Krystal Clear filter pump model 637R. Thinking of getting a SmartPool ChlorEase saltwater chlorine generator.
    domct203's Avatar
    Jun 2015
    CT
    3,592
    Re: Set-up over grass
    Quote Originally Posted by JPC24 View Post
    You need a hard, level surface to put this pool on, peat moss is not going to cut it.
    I would (did) remove the sod (layer of grass) and put your foam/pad on a nice hard, level base. That pool will weigh in at about 33,000 pounds when filled, and will most likely settle un-level as the peat moss is compacted to almost nothing.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    That peat is also gonna get soaked and stink to high Heaven too!
    Jun 2016
    Lynn, MA
    6
    Thank you Dom for your feedback, however the key words are "Easy Set", I want to do this as easy as possible, the pool will only be up for about 8 weeks, and then I will take it down for the winter. So I guess I will take my chances and hope for the best. Thanks again!
    JPC24
    Jun 2016
    Lynn, MA
    6
    Thanks for the feedback Woodyp
    Jun 2016
    Lynn, MA
    6
    I ended up putting down about 3" of peat moss (8 - 3 cubic feet bags) over the grass covering a 16' x 16' area, I then topped off the peat moss with 8 sheets of R-Tech 3/4 in. x 4 ft. x 8 ft. insulation taped at the seams. The 3/4" insulation was much more flexible then the R-Tech 1 in. x 4 ft. x 8 ft. insulation which was very stiff. I did not use the Gorilla pad because it was so thin and seemed like a waste of money, I am sending it back. I filled the pool and so far everything seems to be good. Set up time from start to finish, filling with garden hose (2,800 gallons) was about 8 hours. Grandchildren will have a blast today, Sunday!
    JPC24
    domct203's Avatar
    Jun 2015
    CT
    3,592
    JPC24
    My key word here is 'safety'.
    Please be safe, especially with small children involved. The pool needs to remain within 1 inch of being level or the force of 33,000 pounds of water will mis-shape the pool and eventually cause either a (best case) sudden spill over or (worse case) failure of the liner. When this happens the rush of water can be violent enough to pull small children under water, even when using a floatie.
    This is why both the manufacturer & TFP recommend the pool be setup on a firm, stable base & within 1" of level.
    Good luck. Be safe & keep us posted.
    Dom
    Dom - TFP Guide
    Jun 2016
    Lynn, MA
    6
    Thanks again for your feedback, everything looks good so far, it is level within the 1", safety IS MOST important! The Grandchildren had a blast Sunday (2 six year old cousins, and 8 & 9 year old; have 7 Grandchildren total, also 2 infants, and a 12 year old).
    JPC24
