Thread: borax for stabilizer
    Mar 2015
    South Texas
    411
    So I have a situation that I am preparing for and am using PoolMath to crunch some numbers but I just want to confirm first. By the way, this is not my pool in my signature.
    Details:
    10,000 gallon pool that I am currently SLAMMING, hope to finish tonight. Before the SLAM, PH was 7.2. CYA is 35. According to PoolMath, when I am done with the SLAM of course, I need to add 60 oz. of stabilizer to bring the CYA up to 80 (It's a SWG pool). Also according to PoolMath, that will lower my PH by 0.8, which would make my PH 6.4. I would then need to add 148 oz. of Borax to get it back to 7.2
    That seems like an awful lot of Borax. Is it possible that the CYA will not actually lower the PH that much? 6.4 is awfully acidic. So my basic question is: Do I trust PoolMath and add exactly these amounts? Or should I add the CYA, retest PH, and go from there?
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: borax for stabilizer
    I'd retest after adding the CYA. Did you make sure to measure TA and have that in Pool Math as well?
    Isolated Spa - 345 Gallons
    JoyfulNoise's Avatar
    May 2015
    13,219
    The pool math section entitled "Effects of Adding Chemicals" does not accurately predict pH changes for large additions of chemicals. You'll also note there's a warning there that states the numbers for pH are based on assumptions about the other pool water parameter.
    Adding that much CYA will not change your pH that much. CYA is acidic but it's a relatively small amount being dispersed into a very large volume of water and it dissolves VERY slowly so the pH impact will be minimal at best.
    Matt
    Mar 2015
    South Texas
    411
    WHEW. Thanks for the quick responses. I'm glad I asked before making a possibly huge mistake with someone else's pool
    Man, just when you think you "know" everything. And, no, I haven't even tested the TA yet. Will do that first, add the CYA and let mix for a while (day-ish). Then measure PH before adjusting. Sound better?
