Thread: Pool Store Readings - Help!
    Jun 2010
    Toronto, ON. Canada
    230
    I'm out of town and my wife had to get the pool water tested at the pool store nearby. They do it for free and never try to sell us anything, so when I'm not around, we use them and when I am, we test ourselves.
    They seem to have changed their system and gave her results below (they used to just write down the results on a note paper).
    How do I interpret the CYA reading? Should I be using 100 or 50?
    I always use these as my guidelines from TFP:
    Vinyl with SWG
    FC 3-5ppm
    pH 7.5-7.8
    TA 60-80
    CH 50-300*
    CYA 70-80
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Re: Pool Store Readings - Help!
    Would your wife be interested in learning how to test the pool herself so you could eliminate the pool store altogether? Just a thought.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Unless you exchanged a lot of water I would just assume CYA was whatever you last tested it at. There is no reason to trust that number.
    Also, FC 1-4. LOL
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Oct 2014
    San Antonio, TX
    449
    Not sure I understand the question. Your CYA according to the pool store test is 100. They measured your TA at 50.
    IMO, pay no regards to any of the pool store test. If you are using one of the recommended test kits always trust your testing
    Free form 17X30. 14,500 Gal. Pentair sand filter and 1.5 hp pump. Aqua-Rite SWCG. TF-100 Test Kit w/Speed Stir
    Mar 2016
    Tampa, Florida
    93
    Don't trust the numbers of the pool store. I literally posted minutes ago my experience yesterday with a pool store telling me I had a 100 CYA reading 6/17 and a 10 CYA yesterday. That 100 CYA number was a screw up and the owner admitted and apologized for the store's screwup.
    I'd hate to drain 45% of my pool water because of a pool store screw up.
    Gallons 13,860 / IG Pebble / Hayward OmniLogic / Hayward Swim Clear Filter / Hayward EcoStar / Hayward TriStar VS (for water features) / Hayward HeatPro Heat Pump / Date of build 3/11/16 / Other features: Spa / Hayward Colorlogic LED lights (2 in pool / 1 in spa) / Pentair LED Bubblers (2 one on each sun shelf) / Pentair Color Cascade Laminars (4 around pool) / Taylor K-2006 Test Kit
