Thread: How long for chlorine to drop down to target after reaching shock leve?l
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Had to bring my FC up to shock level yesterday after some raccoons used my pool for a toilet. I turned off the SWG and when I left for work today the test results were:
    FC 22
    CC 0
    CYA 70
    I am wondering about how long it should take to get the FC down to my normal level of 5. The pool gets full sun all day. We are having a pool party tomorrow and I would prefer to have the chlorine level be lower than it currently is.
    Also, I usually don't smell the chlorine but since adding enough to bring it up to shock level I can. I though smelling chlorine meant it was burning off "bad stuff" but my CC is 0. I'm confused.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How long for chlorine to drop down to target after reaching shock leve?l
    If you get full sun all day, the FC is likely to be in the mid-teens by this afternoon.
    The smell is likely the last remnants of CC outgassing after you took care of the raccoon presents. At high FC levels, you can sometimes pick up more of the chlorine smell even in a clear, low CC pool.
    Isolated Spa - 345 Gallons
    Mar 2016
    Port Orange, FL
    363
    Quote Originally Posted by JVTrain View Post
    Thanks! Any recommendation on when I should turn on the SWG again? I'm still so new at this that I don't want to mess anything up for our first big pool party.
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    It will drift down by tomorrow. Have a nice party!!
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Flbeachluvr View Post
    I'd turn it on when your FC reaches about the high level of your FC range. At your CYA, I believe that's 5 ppm, so when your FC hits 5-7 ppm, turn your SWG back on.
    Mar 2016
    Port Orange, FL
    363
    Perfect! Thanks so much for the info
