Thread: RS1000 for IG pools too?
    Mar 2016
    walker/mi
    28
    I bought a 1 year-old Hayward RS1000 over the winter to replace my older-getting-noisier 3/4hp Dura-glas, and then discovered that it's made for AG pools. However, there are several people here who run the same pump for their IG pools. They are self-priming, but in what context, I wonder.
    Is anyone familiar enough with this pump to advise if I should I sell it or keep it around for when my current pump fails?
    26K painted gunite / 24" Cristal-flo (prefilter) to Dayton 4VMN8 cartridge filter / 1.5 hp Pentair Superflo VS pump / Maytronics Dolphin S200 / TF-100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: RS1000 for IG pools too?
    It's a self-priming pump and will work fine on your IG pool. How high above the water level is your equipment pad and how far from the pool?
    Isolated Spa - 345 Gallons
    Mar 2016
    walker/mi
    28
    Nice! The current pump is about 8 feet from the skimmer and less than a foot from the waterline.
    Feb 2014
    Central Minnesota
    5,080
    Your plumbing is likely 1.5" or 2" and that's a very short distance from the skimmer, not much elevation change. Fairly minimal head pressure to overcome with the pump. Should be fine.
    Mar 2016
    walker/mi
    28
    It's 1.5" now, but I have to replace everything and I was thinking 2" to reduce head. It was a koi pond for the last 25 years so there are leaks everywhere from freezing. I lose about 3" overnight if I don't plug the skimmer completely. But I don't mind; we are in love with this pool.
