Results 1 to 7 of 7
Thread: Pool Care Log
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    Pool Care Log
    Besides the actual chemical test results, what else to you make notes on to see trends with your pool?
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Jan 2012
    'burbs of Augusta, Georgia
    7,357
    Re: Pool Care Log
    Water Temperature
    % the SWG is running
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool Care Log
    Aside from the test results, I note the following (recorded in an Excel spreadsheet):
    • Water Temperature
    • Top-offs
    • Backwashes
    • Any other chemicals that are added on an occasional basis (like when on vacation) such as trichlor pucks, Polyquat60 algaecide
    • Temperature hi/lo for the week along with any notes on other weather anomalies that occurred that week or whether we had a pool party that week.
    • Rainfall amounts for the week
    The test results plus the above items are noted once a week. That's enough to give me sufficient trend info. Each year, I save off the prior year's log and start a fresh one for the new year. This way, I can compare trends across years.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Re: Pool Care Log
    Jamie...have you seen the graphical pool log by Jesse? I think it's up to version 3.3 and it's a great visual log if you have Excel. Graphs a lot of things...both current and historical trends and has the PoolMath calculator right in it. Since CSI is important for plaster it calculates that as well and shows you where you are aligned based on your "goals" (desired chemical level). I also track how much of what chemical I've added so I can go back and see the affect over time. You might also want to record pump runtimes which may vary from your normal schedule so you can explain variations in pH rise from aeration (and SWG production like Skippy mentions).
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    JamieP's Avatar
    May 2011
    1,135
    Re: Pool Care Log
    Thank you for those ideas. For now I've been keeping a log in a notebook and wondered what else to include. At one point I'd seen Jesse's spreadsheet and saved it, but didn't take the time to figure it all out because it was a little overwhelming to me. But my husband is the Excel guy, so maybe I'll have him help get me started with it. It looks like a great resource. Thanks for reminding me about it!
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Pool Care Log
    Quote Originally Posted by BoDarville View Post
    • Water Temperature
    • Top-offs
    • Backwashes
    Approximately how much CYA would be added by floating one puck for 5 days (vacation) in 14m gallon pool? Thanks.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool Care Log
    See the Pool Math page. Enter your pool volume at the top and then go to the Effects of Adding Chemicals page near the bottom. Pucks are usually 7 or 8 ounces a piece, trichlor.
    Isolated Spa - 345 Gallons
