Results 1 to 13 of 13
Thread: Please don't laugh at what I bought
    Jun 2016
    Belton, SC
    12
    So I am currently working on my pool project and my wife and I in the mean time decided to buy one of those inflatable hot tubs for our back porch. I have done a lot of research on the Internet and also read the instructions twice, however I cannot seem to find any info on how to properly shock the water and just how much chlorine needs to be added to my floating dispenser to regulate the water. The booklet that came with the tub recommended to use the 1 inch chlorine tablets. The book did not mention how many to use or how to shock the water. I bought a container of them today from Lowes and added TWO 1 inch tablets to the dispenser in an attempt to shock the water for the next day or so. Not sure if I need to do anything else. Any advice from the online community is much appreciated.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Please don't laugh at what I bought
    Here is an article on spa care using chlorine. How do I use Chlorine in my Spa (or pool)?) The tablets will be ok for maintaining chlorine levels, but to reach shock level you need to use liquid chlorine.
    Love TFP? Become a
    TFP Supporter!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    My son keeps begging for one of those. Let me know how it goes.....
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    I have one. I add 1 to 1.5 oz of 10% liquid chlorine per day to keep it right around 3 ppm FC, depending upon how much we use it.
    Sometimes it'll drop below that between dosings, but I haven't had any algae yet. I've been running it this way for about 2 months. Mine also has a saltwater chlorine generator, but it doesn't seem to do much, so I don't run it on any regular basis. It won't run simultaneously with the heater either, so I just add chlorine manually.
    I tried pucks in a floater, but I couldn't find a balance, and pH went through the floor.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Do you have to run the pump 24/7?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    I don't know that I *have* to, but I do.
    Pentair IC40 SWG
    wjr75's Avatar
    Jun 2013
    IL
    836
    If it is in the sun at all you may want to use the dichlor chlorinating method until you get your CYA up to around 30ppm. After that use the liquid chlorine. It's explained in pool school under spa.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    I keep the cover on mine during the day, but I filled it initially from my pool, so my water already had CYA and FC.
    Pentair IC40 SWG
    wjr75's Avatar
    Jun 2013
    IL
    836
    I looked in pool school and didn't see what I used to keep my hot tub going but here is the link. How do I use Chlorine in my Spa (or pool)?). I have a 900 gallon spa and usually bring it up to 7ppm of FC before and after we use it. You usually use 1.5ppm of FC per hour per person in a spa from what the above link and Chem Geek have posted.
    Jun 2016
    Belton, SC
    12
    So far with the little time I played with the hot tub yesterday it has been awesome. I have to go out of town for a few days and won't be back to properly treat the water until monday. Think everything should be fine until then? Or do I need to address this before I head out? Thanks guys!
    Nov 2015
    VT
    84
    I would shock it before you leave (10+ppm) or put a floater in.
    Hot Springs Sovereign (1999?)
    Jun 2016
    Belton, SC
    12
    So I just went out and did a TA, FC and PH test on the water. The FC is above 10PPM right now. The total water in spa currently is 210 gallons. I only had two 1 inch tabs in the floater and never expected it to get the high so quickly. I bought some shock treatment but am considering not putting it in yet since the FC levels are so high. The PH was lower than 6.8 so I added some Clorox PH UP that I bought from lowes and am currently letting it do its thing with the pump cycling water. I am going to go out and check it again her in about 20 mins. The TA was at 0 PPM according to the test stick I used. Once again
    PH less than 6.8
    TA is at 0 PPM
    FC is above 10PPM
    any ideas on how to proceed from here? We are hoping to use he spa when we get home on Monday night so if I shock it I am hoping the FC will be done to less than 5PPM by then.
    Jun 2016
    Belton, SC
    12
    Ok so here's what I decided to do. I went out and raised the PH of the water in order to try to push the TA in the right direction. So far it has helped. The TA is now around 20PPM. Alternatively the PH went from around 7.6 to 8.2. I decided to go ahead and put in the shock treatment even though the FC is well above 10PPM currently. I am going to go out in the morning and add one single 1 inch clorine one tab to the dispenser and leave it covered for the few days that we will be gone. I am off all day Monday so Monday morning I am going to test the chemical levels again, adjust the PH to the correct level and hope that leaving the cover off all day with the sun on it will take the total chlorine level PPM down by that evening so we can get in and enjoy it. Hoping for the best. If anyone thinks I have done anything wrong and has any kind of ideas to get this thing right please please please chime in. Thanks guys!
