Thread: Possible Waterfall Pump?
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    338
    take a look at the pic below. i have my pump that i took off of my old canister skimmer pump. i was curious if i could us it to make a simple waterfall feature? i was thinking of using the old drain that i have hooked up a 1/2" pvc run to an underground french drain. so i was thinking of using that 1/2" pvc and adapt to the pump and run pvc up the side of the pool to the waterfall. i am pretty sure that my 2100gph intex pump could handle the extra return with a ball valve to not have it running all the time. just wanted some input.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Possible Waterfall Pump?
    Those pumps don't produce a lot of head so the lift may not be very high but you could try it with just some flex hose to see how high it will pump.
    Mark
    Apr 2013
    Sacramento, CA
    2,769
    In addition to marks point you may not get the volume you want.
    chayne's Avatar
    May 2016
    338
    Ok thanks for the info. I just hate seeing that pump sitting there.
    Charles
    Coleman 16'x48"
