Results 1 to 9 of 9
Thread: Slamming with DE filter
    Jul 2013
    NJ
    4
    This is my first time ever using a de filter. right now im thinking it might have been a mistake....
    took the cover off and the pool was completely green so i researched a little and found out this slamming method and thats what im doing. i am not having problems with the slamming part. well i dont think i am. what i am having concerns with is the de filter. i backwashed it today added more de and within an hour the pressure is going up 7-10 psi. (never higher than 10psi) which according the the filter im supposed to backwash again and add more de. if i just bump it the pressure will climb back up within a few mins. if this keeps up ill be spending hundreds of dollars in de.
    38,398
    Re: Slamming with DE filter
    Welcome to TFP!!!
    Yup, that is the downside of a DE filter, they are very good at filtering
    If you have a recirculate option, you could do that until all the algae is dead and then filter it out.
    Note we recommend backwashing when the pressure rises 20-25% over the clean pressure.
    These might be useful:
    Use and Care of DE Filters
    DE Filter Cleaning Tutorial
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Brett,
    DE filters are very efficient. They will clog quickly if you get algae.
    If you have a re-circulate position on the filter valve, set it to recirculate until you make some good headway with the slam. When you can start to see the bottom, vacuum to waste. Then after that that, set it back to filter.
    Divin Dave,
    Jul 2013
    NJ
    4
    thanks for the quick replies...unfortunately i do not have the recirculating option..so does this mean lots of backwashing and lots of de?
    if thats the case i might just disconnect the filter lol
    38,398
    Bummer. You could open up the filter and remove the whole grid assembly.
    Jul 2013
    NJ
    4
    added 5 more gallons of bleach yesterday dramatic improvements overnight. can see the bottom now and looks like most of the algae can be vacuumed up now. amazing 10$ of bleach and were back in business
    10,000 gallon above ground. hayward 1-1/2hp dual speed pump. hayward ec40ac de filter. SWG
    Jun 2014
    15,194
    Outstanding! Now don't let that clear water fool you. Continue the SLAM until you pass all 3 criteria. Give it the knockout punch otherwise if can resurface. Your progress sounds very promising. Have a nice weekend.
    Jun 2016
    Marlboro, NJ
    176
    yeah i had to backwash like 3 times within 2 days when i had a green pool at opening.
    but DE isnt that expensive relative to other things that pool stores try to jack you for.
    Pool Type: In Ground, Liner. Shape: Free form/kidney
    Filter/Pump: Brand new (2016) DE Hayward 4820 / Brand new (2016) Pentair VST 2
    Heater: Yes (older)
    Location: NJ. No tree/leaves overhead. Limited shrubs near/over waterfall feature
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,108
    DE can be bought at Lowes, Home Depot and even some Walmart stores. Just be sure it's the pool kind. Saves a trip to the pool $tore.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
