Results 1 to 18 of 18
Thread: Walmart pool essentials 10% chlorine
    Apr 2016
    Murfreesboro, TN (Middle TN)
    103
    If nobody noticed Walmart just went from 2.50 to 3.64 on this stuff. Anyone else have a good source?
    27' above ground, 17500 gallons, Cartridge filter Hayward SW1000z4, A.O. Smith Pump SP1515Z1BC 70 GPM, Test kit Taylor TF-100
    Murfreesboro, TN
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Re: Walmart pool essentials 10% chlorine
    Quote Originally Posted by mjnorman View Post
    Sent from my SM-G935V using Tapatalk
    I saw a 6-pack at Orchard Supply today for under $5. Didn't list the percentage of SH so I left it there.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    Jun 2015
    Wheatfield, IN
    37
    Do you have rural king by you. 4gal of 10% and it is $8.
    18' round above ground est 8600 /gal with Hayward sand filter filled with well water
    Jun 2013
    Buffalo, NY
    80
    Up here the stuff on the shelf is back to $3.64. However, they still have a pallet of the 3-pack box marked at $2.50/bottle. Relatively fresh stuff too. I just stumbled upon the pallet so look around, they may still have those where you are.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    May 2016
    MD
    195
    darn... Ollies may still be at 2.50 for 12%... glad i bought 20 bottles earlier this week
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    May 2016
    Troy IL
    476
    I just got back from my Walmart in Glen Carbon IL and they had their chlorine at 2.50 still. I went ahead and bought 10 gallons since I was able to find several with date codes of 16 166. There was a lot of 158 also. That's only a week or so old.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    345
    my walmart went back up to $3.64 this weekend also. i went to get me some more, but when i saw that i just kept on walking. i did however get 8 gallons before the price went back up
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    BNilsen2693's Avatar
    Jun 2016
    Tulare, CA
    28
    I noticed that both Home Depot and Lowe's sell 10% Chlorine.....about $6.75 for a box of two one gallon bottles.
    BNilsen2693 -- 30K Gallon In-ground , Pebble Tec, 55' at the longest, 24' at the widest, 8' at the deepest, Pentair FNSP60 DE Filter, Polaris Sweeper running off a booster pump. TF-100 Test Kit.
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Just bought two bottles at OSH for $5.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Yeah, I noticed.
    Divin Dave,
    Jun 2015
    Freehold, NJ
    20
    My Wal-Mart in Central NJ still had the 10% bleach for $2.50. Very fresh too according to the Julian date.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by BNilsen2693
    Just make sure to check the date on these, especially since they tend to store this outside where it is more exposed to the heat. I purchased some of this from HD or Lowe's a while back and found out that my 10% had degraded to 6% based on my testing and how much I had to add to reach my FC target.
    Apr 2015
    Brookline
    60
    my walmart had it priced 3.64 but rang up 2.50. Hudson NH
    Southern New Hampshire, 18x36 single roman end pool.
    May 2016
    Katy, TX
    1
    Question from a newbie - I too have been picking up the $2.50 10% chlorine at Wal-Mart in west Houston lately. How do you know if it's fresh, i.e., how do you interpret the date on the bottle? The bottle I'm currently feeding my pool with has a stamp that reads "16 166 14:07 B2 TX-01."
    I'm LOVING the TFP pool method!! Gave up on the pool store after a nasty algae outbreak this spring and they sold me $150 worth of chemicals. Figured there HAD to be a better way, and friends steered me here. Happiness is a crystal-clear pool and the control freak in me is in heaven with knowing my water is perfectly balanced daily!
    16K-gal IG gunite w/ Wet Edge satin matrix midnight sea, raised spa, built 2014
    Pentair equipment (Intelliflo VS whisperflo pump, cartridge filter, 1hp water feature pump, 400,000 BTU master temp heater, Easy Touch 8 wireless control system),
    Polaris 280 cleaner
    Taylor K-2006 test kit
    Jun 2012
    Butler, PA
    336
    16 is the year 166 is the 166th day of that year.
    for 2016 the 166th day is June 16th (we had a leap year this year I believe).
    Edit to Add:
    Julian Calendar Date Stamp
    If you google Julian Calendar for 2016 you can see what number range you should be in for your purchases.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    May 2016
    MD
    195
    Quote Originally Posted by jmoore97 View Post
    that date is what it is. Wish the store near me had those dates... Starting to wonder if i have to go find another one... one closest has 15's left unless the 16 is just screwed up.... but mostly 100th day stuff... and 1 121 left... as i bought all their 147 days a week ago. so yea. i just learned this too. 166 day of 2016
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    If you use Google calendar, you can add the Day of the Year calendar to put the Julian date into your calendar.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Sep 2015
    Ky
    23
    my walmart still has it at 2.50 bought 15 jugs yesterday all dated June 10th 2016
    My pool 20x40 Vinyl Liner 24k gallons Sta-Rite P6E6E-206L Max-E-Pro Energy 1 HP System Filtration DE Polaris BP960 pump Heater
