Thread: Solar cover questions
    Can I operate my filter and polaris with the solar cover on?
    25K Gal, IG gunite, Hayward 1HP pump, Hayward DE filter, Pentair Mastertemp 250, TF100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Solar cover questions
    Filter yes. I'm not sure about the Polaris.
    Often the cleaner hose will have enough friction against the cover to cause problems. You can try it out, put it probably won't work.
    Jan 2009
    Cupertino, CA
    1,966
    My Polaris doesn't mind the cover. There's definitely some squeaking as the hose slides around under the cover, but I haven't noticed any actual problems. I think the cover is 8mil but at this point I'm not sure.
    If you have the cover in sections, I would run the sections so the long side is against the wall that has the Polaris fitting in it. That way the gaps between sections are less likely to get dragged by the hose as it moves around.
    --paulr
    BBB "Intermediate Swimmer"
