Thread: Hayward Skimmer for a Intex Setup
    Jan 2015
    Puyallup, WA
    50
    Ok I have posted here before but this weekend is when I will be installing the new skimmer and we can't wait to dispose of the Intex over the wall. So in the below picture where is the best place to put the skimmer. The Intex inlet is to the left and the return is the one on the right which I assume everyone already knows that.
    I plan on just using the intex hoses until I have time to hard plumb. I waned to hard plumb but due to timing this year this may have to wait until next summer we have my son's Bday party on Sunday which I know I wont have the time to get that completed by that time.
    So do I just close the intex plunger and just use the skimmer and my original return valve?
    Do I place the skimmer to the left or right of the Intex inlet?
    Thanks in advance!!
    20x10 Intex Pool
    Sand Filter SF15110, Solar Cover
    TF-100
    Jul 2014
    Oakbank, Canada
    389
    Re: Hayward Skimmer for a Intex Setup
    The hose on the right comes in from the pool, the one on the left goes back into the pool. When drawing water from the pool it comes through the strainer basket first, into the pump, then through the sand filter.
    I would place the skimmer to the left of the right hand hose, between the uprights. You would just shut off the valve, undo the hose from it, and then put into the skimmer.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    AnnikaF's Avatar
    Apr 2015
    Southampton, UK
    36
    this is how i did my skimmer and hard plumming.
    http://www.troublefreepool.com/threa...ild-with-pic-s
    Chris - Annika's papa
    9x18 Intex ultra AGP 4500 gallon, 3200gph intex 1hp pump with 16" sandfilter, abs hardpiped, hayward skimmer, Intex SWG, 11kw heater, LaMotte ColorQ Pro 7 test kit.
    Jan 2015
    Puyallup, WA
    50
    Quote Originally Posted by DarrelB View Post
    Ok thanks. You answered my question to the left of the inlet which is what I was thinking but wanted to be sure because I cut a hole in the liner
    Thanks again,
    20x10 Intex Pool
    TF-100
