Thread: pH drifting upwards - is it polyquad?
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    I haven't opened yet (Tuesday is the day) and meanwhile I keep FC and circulation using sub pumps at 3000 gph.
    Initial numbers:
    CYA 8
    FC 1
    CC < 0.5
    0< Ammonia <0.25
    Alk 90.
    I also added some 60% polyquad. Before I added the alagaecide pH was steady at 7.3 - 7.4, but after that it drifted to 7.7-7.8. Is this a coincidence?
    We've also had some rain but rain here is acidic.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: pH drifting upwards - is it polyquad?
    not sure if it is the poly, but it could be the rain...although your rain water may be on the acidic side, it is a very good source of aeration which could raise your PH.
