Thread: More granular measurement of TA
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Is there a way to measure TA in a more granular way other than in increments of 10? Can I take 50ml of water and double the amount of each of the drops and get a measurement graduation that is in 5ppm? Not sure if this is a linear scale or not, but I'm looking for something a bit more accurate than 10ppm. (Yeah, overkill, I'm sure, but trying to understand the chemistry a bit better. TF-100 test kit, btw.
    15' x 29' 10,300 gal w/ spa, IG-Plaster (Stonescapes Tropics Blue), 2spd WhisperFlo pump (1.5hp WFDS-26), Pentair Clean and Clear CC200 cartridge filter, Pentair MasterTemp 300BTU heater, Clear o3, RS-8 iAqualink
    Mar 2015
    Georgia
    157
    Re: More granular measurement of TA
    You can use a 50ml water sample. You'd have to have your own beaker that goes to 50ml.
    Add 4 drops of R-0007.
    Add 10 drops of R-0008.
    Each drop of R-0009 counts as 5 ppm TA.
    16k AG Vinyl Sand Filter
    30,431
    Waste of time. the precision of that test is plus or minus 10 ppm......regardless of the sample size.
    For pool needs, TA has a very wide range to begin with so the test meets pool standards just fine but it will not do better than 10 ppm.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Thanks Smackdab. Just validate my think. And yes, I have a graduated cylinder that goes up to 100ml.
    Appreciate the reply duraleigh. This was more for my own understanding than any need. I loved science in school, but haven't had a need to use Chemistry in real life in over 30 years. Trying to figure everything out all over again is...dare I say...fun. Good to know I was thinking about this straight.
    JoyfulNoise's Avatar
    May 2015
    13,247
    This thread has a good list of the modifications you can make to the drop counts of the various tests to get different precision - Water Testing - Precision vs Saving Reagents
    Just remember that the testing tolerances change with different levels of precision.
    Matt
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Wow...that was a good read. Thank, Matt!
