Thread: Recurring Algae Problem
    Feb 2014
    Ft Lauderdale
    2
    Hello all. I have an algae problem that I cannot get rid of. I have been following these forums for a while and the slam protocol. My latest slam was about 2 weeks ago. I discovered algae again yesterday. My FC level never dropped below 5. I reluctantly had my water tested at the pool store today.
    TC - 5
    FC - 5
    Combined chlorine - 0
    pH - 8
    total alkalinity - 100
    CH - 275
    CYA - 80
    salt - 3100
    Phosphates were about 1000.
    I understand from these forums that phosphates shouldn't matter as long as the FC level is maintained. But this last time my FC level was at 5 when the algae occurred. I'm in the process of starting another slam. One issue I have is that we have a tiki hut and the overhang is over the pool so that whenever it rains we get a lot a dirt / dust from the tiki roof. Is it possible that I need to maintain a higher FC level? Or should I just use the phosphate remover? I live in south florida and also have the TF-100 test kit.
    Thanks for all the help
    Dave
    15x30 in ground, 14,000 gal, 2hp pump, autopilot digital nano salt system, Florida Stucco Gem Finish
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Recurring Algae Problem
    Absolutely keep your FC a bit higher if you're having repeated problems. Your target level is 6, never to drop below 4. So aim a bit higher than 6 (like 8) and then the normal daily FC loss won't take you below 6.
    Your pH is too high, and you need to get some muriatic acid in there (using PoolMath as a guide).
    Phosphate remover just isn't necessary if you keep your pools chlorine level at the appropriate level. If you have problems doing so....well...it might help but doubtful.
    domct203's Avatar
    Jun 2015
    CT
    3,578
    Quote Originally Posted by attydy View Post
    TC - 5
    FC - 5
    pH - 8
    CH - 275
    CYA - 80
    salt - 3100
    Dave
    Welcome!
    Would you please post a full set of results from your TF-100? We don't trust the pool store testing.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Feb 2014
    Ft Lauderdale
    2
    Quote Originally Posted by domct203 View Post
    Welcome!
    Dom
    Test results for 6/24/16
    FC 29
    CC 1
    TC 30
    Ph 7.8
    TA 100
    CYA 80
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Hi and welcome.
    I can feel your pain on reoccurring algae. It's coming back for a reason. Basically that is not enough chlorine on a daily basis or not passing all three tests when going through SLAM process.
    May I suggest when proceeding to SLAM, consider taking out light fixtures where algae might be hiding behind those in the niches. Looking for any cracks and crevices where algae might be hiding. And brushing those. I've been through this and found algae within the skimmer box plates caked up a good bit. I've found it where my fiberglass steps meet the vinyl.......I could go on and on. Last year I dedicated a kitchen hand held scrub brush to the matter and sent the kids to work on all of the tiny cracks and crevices while they were in the pool. That's when I became such a huge advocate of brush brush brush.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    domct203's Avatar
    Jun 2015
    CT
    3,578
    FC 29
    CC 1
    TC 30
    Ph 7.8
    TA 100
    CYA 80
    Alright, looks like we're SLAMin'. I hope you dosed to get the FC back up to 31.
    Dom
    Dom - TFP Guide
