Results 1 to 13 of 13
Thread: TF-100 arrived today. Here are my results
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    341
    FC=11
    CC=0.5
    CYA=50
    TA=160
    pH=7.8
    i am about to see how this all looks. let me know what you all think
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Jan 2012
    'burbs of Augusta, Georgia
    7,366
    Re: TF-100 arrived today. Here are my results
    How does your water look? Were you SLAMing it that your FC is on the high side? If not it will drop on its own in a few days- no worries there.
    Reference for Levels: Pool School - Recommended Levels
    Your TA is high, which drags your pH up too. Use Muriatic Acid to lower both, then use aeration to raise the pH back up to 7.5 or so. Here are the directions-->
    Pool School - Lower Total Alkalinity
    chayne's Avatar
    May 2016
    341
    no i was not slamming my pool. the pool water has been crystal clear. i appreciate the link for the recommended levels. i had not seen that one. i am planning on going by the Depot on my way home tomorrow to pick up muriatic acid. would it be ok to just point my return jet up because i have not made a fountain yet.
    Charles
    Coleman 16'x48"
    Jan 2012
    7,366
    Another option is to use a sump pump if you have one, placed on a stair secured and let the return hose pump that water immediately back into the pool with a bit of splash. But yeah, the return jet will work too, but perhaps slower.
    Sep 2015
    Rome, NY
    363
    I turned my one return up. Slower but if using the pool the splashing helps.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    chayne's Avatar
    May 2016
    341
    ok, thanks for the info.
    Charles
    Coleman 16'x48"
    30,431
    What are we doing with the aeration??? That raises pH and you sure don't need to!
    Assuming your water is crystal clear, I would leave everything as it is. Sure, your TA is high but it will naturally come down.
    It seems like you are3 fixing something that isn't really broken and will get better on it's own.
    chayne's Avatar
    May 2016
    341
    So basically I do not need to do anything. Gonna have about 10 people over for 4th of July next weekend. Do you think it will be ok?
    I think what everyone was saying was that once I put some muriatic acid in that it would bring TA down as well as ph. Then the aeration would help to bring ph back up. I think that is what was said
    Charles
    Coleman 16'x48"
    30,431
    Yeah, I see where you were going but your pH is as high as you want it. Just leave everything alone and monitor. I would check pH daily because I think it will (on it's own) jump to 8.0 and THEN, you need to add muriatic to bring it down somewhere around 7.4....that's it...leave TA alone.
    Monitor pH every day or couple of days. Post back if it jumps to 8.0 again. If it keeps doing that, THEN you can adjust TA.
    Certainly, go swimming on the 4th. That what pools are for.
    Jan 2012
    7,366
    Yes, that's what was said. I personally would do it as I like things "in order" and as close to ideal as soon as possible. A high TA makes the pH rise faster. So its your call.
    Apparently Duraleigh has more patience than I, knowing that throughout the season as your pH rises and you lower it with MA, it will eventually bring that TA down too.
    Yippee
    chayne's Avatar
    May 2016
    341
    Sounds good guys. Thanks for all the info. I think I will try to be patient. That is a virtue isn't it? I know it is hard to be patient with these pools. I know I want everything perfect overnight and it just cannot happen. If it jumps to over 8 I will be at the Depot buying some muriatic acid
    Charles
    Coleman 16'x48"
    Jan 2012
    7,366
    Sounds like a reasonable plan and good to know what you need to do before you *have to* do it
    chayne's Avatar
    May 2016
    341
    could not agree with you more. i sure dont want to be in that place where "I have to do this and this to get back to normal"
    Charles
    Coleman 16'x48"
