Thread: Swim while Slamming?
    Jun 2016
    Oradell
    22
    How long do I need to wait before letting the kids back into the pool during/after slamming?
    28,000 Gallon, Inground Vinyl, Pentair FNS Plus 60 DE Filter, Pentair Superflow High Performance 1.5 HP pump, Pentair Intellichlor IC40 SWG, Pentair Master Temp 400 heater, Polaris 280 cleaner w/ booster pump, Taylor K-2006 Test Kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Swim while Slamming?
    Any time your FC is less than the shock level indicated on the Chlorine/CYA chart, it's safe to swim.
    Other considerations for safe swimming:
    Water must be clear so you can see the entire bottom of the pool, for safety.
    CC level should be 0.5 ppm or less to confirm a clean pool and less chance for skin/eye irritation.
    pH should be between 7.2 and 7.8
    Isolated Spa - 345 Gallons
    Jun 2016
    Oradell
    22
    Appreciate the feedback. Thanks.
    38,290
    Ideally you do not try to do both at the same time. Swimming slows the SLAM.
    Just remember you will not melt as soon as the FC is above shock level
