Results 1 to 7 of 7
Thread: Intex Pump Leaks
    Jun 2016
    Rockaway Beach
    3
    Intex Pump Leaks
    No matter how hard I screw on the lid and make sure it's even/level, the pump still leaks despite the O-ring being present etc.
    Anyone else with this problem?
    Should I just upgrade away from these pumps? This is my 2nd one after the first one never worked. Leaks in area highlighted in green.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Intex Pump Leaks
    Welcome to TFP
    You can try some pool lube and see if it works but the most promising way is to replace it with a 2800 or 3000 GPM intex sand filter, they actually work
    Mid Missouri
    227
    I agree, even if that filter wasn't leaking you'll be much happier with an Intex sand filter.
    Jun 2016
    Rockaway Beach
    3
    OMG, so frustrated!
    So I read everything I could on getting a larger better pump, I can't use the 2800 or 3000 GPM pumps as my pool is only 3,000+ gallons, so I bought the 635T model and everywhere it stated it is 1 1/4" hose, only to find out it is 1 1/2". So unless I empty the pool below the holes there's no way to use this pump. So annoyed!
    Jun 2016
    bc
    152
    Ok not to sure why you could not use the larger pump. But you can buy a 1 1/4 to 1 1/2 barbed reducers at your local hardware store or any ware that sells plumbing supplies. Then all you need is a short pc of 1 1/2 hose and your good to go... I quickly googled it and all the descriptions i found said it was a 1 1/2 pump but said their is also a adapter you can buy for 1 1/4 hose. To get the parts at local hardware store including a pc of hose your easily under $10 in parts
    Aug 2013
    south east Arizona
    200
    Amazon.com: INTEX 1.25 Games
    Amazon.com : INTEX 1.25 Garden
    I think I have a set of the lower ones that came with my SWG I don't need. I can mail them if you are comfortable giving me your address. Send me a PM if you want. Won't go out until tomorrow but should get there Tuesday or Wednesday.
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
    Jun 2016
    Rockaway Beach
    3
    Quote Originally Posted by Pv2 View Post
    Ahhh! I wish I saw this before, I searched and searched & found that one you posted, Amazon.com : INTEX 1.25 Garden bought it & it arrived today. New pump to be installed tomorrow! Thank you all for your support! Love this site!
