Thread: Multi-Port Leaking into Waste Line
    Been a rough week for my pool. I have a hayward sp710xr50 Vari-Flo. Long story short, I took my plumbing apart to replace some parts. I put everything back together except for putting the hose back into the "waste" port. I started the pump on "filter" setting and noticed some water coming from the "waste" port consistently (which may explain some of my dropping water level suspicions). Do I need a new multi-port or do I just need to replace the valve seat gasket? Thank you.
    Chad
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Multi-Port Leaking into Waste Line
    I would start with the gasket and see if that fixes the problem.
    Part should be in tomorrow. Hope it's the fix. Thank you.
    May 2015
    kingston springs, tn
    102
    It sounds like the Spyder Gasket. Inyo pools has a good instructional replacement video on their website.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    Just replaced the spyder gasket and still have the same issue. Maybe I need to buy a new multi-valve? No clue how the water is getting into the waste port when it is set to filter.
