Thread: Dissolve 2 lbs granular CYA in 1 hour?
    May 2015
    Fort Mill, SC
    179
    Too good to be true? Normally I add approx 2 lbs at a time in a sock in my skimmer. This time around, I switched to a different brand (Aquabrite Chlor-Sta) and hung the sock in front of my return. This brand is perhaps slightly more granular, but not by much. There was a white fog trailing out from the sock like a comet's tail, and it didn't take long at all...1 hour later it is mostly gone. In front of the return, there is a lot more turbulence and the sock gets buffeted around a lot more. The sock is not compromised in any way, no undissolved granules escaped as far as I could tell. Typically I see it dissolved in the skimmer after 24 - 48 hours.
    20K gallon vinyl inground pool, Hayward Pro Series sand filter, 1 HP pump, Taylor K-2006
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Dissolve 2 lbs granular CYA in 1 hour?
    Yup it can happen!
    Jul 2009
    Long Island, NY
    267
    I have also noticed that it dissolves much quicker with warmer water temperatures.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    May 2015
    Fort Mill, SC
    179
    Cool, I'll verify it with the turbidity test tomorrow. My water temp is 86 F. I'm trying to recover from a catastrophic loss of CYA, and this will surely make things easier.
