Bumping my own thread, please let me know if this is not allowed.
I was finally able to purchase my own testing kit, ended up getting the Taylor K-2006 with speed stir (what an amazing tool). Due to my salt issues, I had to do another partial drain of my pool this weekend so this was the perfect time to get my pool balanced the TFP way.
Most recent test:
FC: 4
CC: 0
CH: 300
TA: 90
PH: 7.5
CYA: 60
Salt : 3500
I know that with an SWG, it is recommended to have at least a CYA level of 70 so I added 14 oz yesterday based off the pool math calculator. I am also adjusting my SWG to get me to my FC target of 5. Once I get those two squared away I am going to start on my TA to help lower the amount of acid my intellichem is going through. Only problem is that this is all going to be for not when my salt levels go up again and I have to do another partial drain. If you don't want to read the entire thread, I am having issues with my salt increasing very quickly. I was told it could be the amount of acid I'm dumping in, then it dawned on me that it could have been my auto-leveler was on the same line as my softener, but it looks like its my fill water.
I tested my fill water prior to the softener (spigot out front), in the house (kitchen sink), and from the auto-leveler, they all have the same salt content, 1000ppm. To make sure I was not crazy, I even tested two of my neighbors water supplies and discovered they too had the same 1000ppm. I tested each one several times to make sure I did not mess up the testing process, 10ml sample, 1 drop of the yellow (chromate indicator), turn on speedstir, add one drop of the silver nitrate at a time until the solution turns brick red, multiply drops by 200. To really make sure I was not crazy, I did test the hardness of my water and as expected, the faucets in the house were indeed soft (40ppm or less) while the faucets outside were much harder when using the K2006 to test.
Should I call the city, I dont think 1000ppm sodium chloride is normal for drinking water?
