Results 1 to 11 of 11
Thread: New pool owner and my water is like a pond.. I'm need of some assistance!
    Jun 2016
    New york
    6
    I just recently bought a house which has a 15' round above ground pool which was not taken care of. I have never been a pool owner till now so I don't know too much about pools. I have been attempting to use a leaf rake and a leaf eater to clean the pool, however it's hard to tell how much debris is in the pool due to the dark water color. Also my pool has a ton of tadpoles swimming around. I'm trying to clean it in order to SLAM it. Also my pool is currently only half way filled, we had to drain some to get the cover out and leaves that were on the cover. when should I refill it? Any suggestions or advice would be terrific!
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: New pool owner and my water is like a pond.. I'm need of some assistance!
    Welcome to TFP
    The best thing you can do is keep at it removing debris, as horrible a task as that can be. Do you have the right test kit ready for starting a SLAM?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    Congrats on the new swamp,
    First thing I would do is order a TF-100 with the XL option from TFTestkits.net. With your own great test kit you can easily take care of your own pool.
    Fill the pool, scoop out as much as you can add 20 oz of bleach daily and brush until you get your test kit.
    Read this, SLAM and be ready.
    Mar 2015
    US
    122
    With a 15' round, half empty pool, you would need about 3000 gallons to fill it. If it was my pool, depending on the price of water in your area, I would empty it all the way, scrub it out and refill with about 6000 gallons of clean water. The savings are only 3000 gallons by slamming it.
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    Jun 2016
    New york
    6
    I bought a test kit from Walmart not realizing I would need a better one. Silly new pool owner. I've been looking into buying a better one not sure if I should get the tf-100 or the Taylor k-2006. Any suggestions?
    Should I be running the pump and the filter while cleaning and dumping 20oz of bleach in the pool, while I wait for my better test kit?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Quote Originally Posted by Davejavu View Post
    I am with him ^^^ on this one. I would take some more of the water out. Leave enough water to come to lower or mid shin. Catch and scoop out all of the tadpoles then work on the solid yuck. That is what I had to do when we moved into our house. Once you have all of the yuck out you can get start filling it back up.
    I would get the TF-100 because it has more of the regents you will use on a daily bases.
    While all of this is going on look around your area.........where is YOUR best buy for chlorine/bleach? Some find it at Walmart-pool shock or Greater Value plain bleach, some find it at their pool store using the "rented" jugs.
    Do some reading to learn the hows and whys of TFP. Here is what I give to all new pool owners. It is a LOT of info so take it slow and let it settle in:
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    Kim
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    I'm in the dump it and start over camp.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    DFW, TX
    24,450
    Definitely more of the tests you need in the TF-100 from TFTestkits.net. That is what I use. More here, Pool School - Test Kits Compared
    Jun 2016
    New york
    6
    Thank you so much for all the help. I am trying to continue to clean the pool waiting for the pool test kit to arrive. Then I am hoping to fill the pool up to where it belongs and run the pump and filter and start to slam it. Hope I am making the right decision to not drain it and save the $500 plus it would cost to refill it.
    Aug 2014
    Northern IL
    4,615
    Okay. We got your back. Add 1/2 gallon of bleach everyday until your test kit arrives. Keep scooping debris and brush at least daily.
    Jul 2012
    Tallahassee, FL
    30,410
    $500 to refill? OUCH! Yeah lets clean that thing up!
    Kim
