Results 1 to 7 of 7
Thread: 3 Way Valve Question
    Apr 2016
    Portland, OR
    50
    This is a photo of a 2 in (inside slip) Pentair 3 way valve that I purchased. I was disappointed to see that the design incorporated what looks like a substantial flow bottleneck (see the "eye" shaped PVC in the inlet). My question, can someone tell me if the other brands of 3-way valves also have this eye-shaped bottleneck? My pentair 2-way valves have a round inlet-stop that meets flush with the diameter of PVC that is intended to fit inside the slip, so I know it is possible.
    Thank you!
    18x36 in-ground, ~29k gallons, Pentair 3HP VS, Pentair CC+ 420, IC-40, EasyTouch Panel, In-ground cover, 100% DIY-reworked pad (thanks to help from this forum), TFP Test Kit, Near-antique heat pump...
    38,284
    Re: 3 Way Valve Question
    Once you put the pipe inside, then the "eye" shape is nearly gone. I would not call it a "substantial flow bottleneck" if you are using 2" pipe. If you were using 2.5" pipe with a coupler on the outside, then it would be more of a bottleneck.
    BUT, a short restriction like this does not add a huge amount of head loss and will have very little impact on the flow rates.
    Apr 2016
    Portland, OR
    50
    It's still significantly present when viewed with a 2 in seated. I'm trying to avoid any headless due to poor design, it all adds up. Anyone know about other brands?
    38,284
    Much ado about nothing, IMO
    Apr 2016
    Portland, OR
    50
    Gottcha. Wondering about other brand valve designs, eye or round inlet stop? Jandy, others?
    38,284
    I only have a couple Pentair valves at home, so no other brands to offer pictures ... perhaps someone else has pictures to offer.
    I just found this about the Jandy, different, but still appears to be some blockage:
    http://blog.poolcenter.com/article.aspx?articleid=6209
    Apr 2016
    Portland, OR
    50
    Good find, thanks. Perhaps something about the 3-way seal design that requires that shape or similar.
