Thread: Brushing a pool (every wee no matter what?)
    May 2016
    MD
    195
    I think this is where I fail a bit... I do have a polaris sport that runs around the bottom... seems to get most dirt... but not all as when I do brush lots of stuff moves around in different areas.
    But do you have to brush a pool no matter what. I guess I ask cause I always see brush while SLAMING, but I guess it is just a normal thing to do... and I forget.
    I wish i bought a robot instead, but i didn't know anything at the time.
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Brushing a pool (every wee no matter what?)
    At a minimum, the pool should be brushed in it's entirety every week. The Polaris should allow you to brush the bottom less and help with circulation, but you should certainly brush the sides each week. I have a robot and sometimes I get a bit lazy and don't brush every week, but my robot climbs the sides and does a pretty good job on the entire pool.
    Isolated Spa - 345 Gallons
    30,426
    Whether you get a robot or not, brushing a pool is standard maintenance.....no exceptions
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,261
    Sometimes it looks and feels like you're doing nothing, but you're dislodging dirt and dust, along with breaking the biofilm which forms over algae cells to protect them from the chlorine, especially in areas with poor circulation.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
