Thread: Observations from a Rookie
    Jan 2016
    Houston/TX
    10
    As the title implies I am new to pools having finished our pool in February of this year, but I wanted to share some observations with the crowd and maybe get some insight maybe share some insight.
    1. I started off chlorinating with a 50lbs bucket of Tricolor until my CYA reached 40 then switched to Liquid Chlorine 10% which I obtain from Walmart for $2.50 per gallon. Cheapest I could find around here. I also use Borates.
    2. Since then I am noticing with the brutal sun that I am dumping 1/2 Gallon per day (sound about right experts?) to maintain 3-4ppm
    Cost Analysis
    Using Liquid Chlorine
    $1.35 roughly after tax per day x 365 = $492.75 per year or $41 per month roughly
    If I had continued use of TriChlor
    InTheSwim = $108 for 50lbs which lasted 2 months
    Cost per month $54
    Some have asked which is cheaper and they are close upfront in my observation but TriChlor will end up costing you more. Which is easier? Neither! Keep in mind you either put up with having to monitor your CYA and empty 50% every year and then spend more money rebalancing all your chemicals or just deal with the hassle of adding chlorine every day.
    Note: I shock with Liquid Chlorine as well. I do keep some CalHypo and some TriChlor around for when I am on vacation.
    My current readings
    ALK 90
    PH 7.5
    FCL 4
    CAL 200
    CYA 40
    Hope this Rookie didn't muddy the water. I try to research the heck out of things before getting into something. Plus I love testing water I have aquariums and YES my Fish are all alive.
    Enjoy the Hot Summer!
    33' x 21' + SPA, Approx. 20k Gallon, Gunite, Freeform, Natural Rock Features, PebbleTec Tahoe Blue Plaster;
    Hayward SwimClear 425, 400k heater, EcoStar Variable Pump, 1.5h Booster Pump, Polaris 280 Cleaner, Autofill;
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,610
    Re: Observations from a Rookie
    LOL glad all of the fishes are still alive! That IS a good thing!
    VERY interesting findings for sure!
    Thanks for sharing!
    Kim
    Jan 2016
    Houston/TX
    10
    had calculation off. sorry. I noticed that and corrected.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Its been quite a summer in Houston so far, from flood to furnace in the course of 4 weeks!
    Love TFP? Become a
    TFP Supporter!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Great analysis, but I do have a couple comments:
    You say -
    With 40 CYA 3 is the absolute minimum you should ever have. You probably should target 5 or 6 to make sure you never drop below 3.
    You say -
    Following TFP methods there is no need to "shock" your pool. If you are seeing algae, it is probably because of my first comment and you need to SLAM. If you are not seeing algae or experiencing high chlorine demand then there is no need to "shock". That is just wasted chlorine.
    Support the site
