Page 1 of 9 1234 ... LastLast
Results 1 to 20 of 164
Thread: New Pool - Southern New Jersey
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    Good Morning Everyone,
    I just came across this forum late last night. I signed the contract and put the initial deposit down on our new pool yesterday morning and am now doing what I do - over research pool ownership to death and I found this forum. It's kind of exciting, but worrisome at the same time! And, I am of the generation that want it in this weekend and have to wait until mid to end of August to swim.
    Here is the pool design. It will have a raised beam between the pool and spa level of 23-30" because of a slope in my backyard. The pool will be 18.5' x 42' (777 square feet) and will have a 40 square foot spa with 6 hydro jets.
    Equipment:
    Pump - Hayward 2hp Tristar
    Filter - Cartridge 450 Foot Commercial-rated
    Heater - Hayward Universal H-Series ASME Natural Gas 400k BTU
    Salt Water System - Hayward Aqua Rite
    Pool Cleaner - Hayward Phantom
    Lighting - 2 ColorLogic lights in pool and 1 in Spa
    Automation - Hayward ProLogic
    Air Blower for Spa Jets
    2 Deck Jets from upper deck into the pool
    Pre-plumbed for spa
    Considerations:
    We are thinking about adding a tanning ledge to the design, but are not sure where to place it in the pool. Given the shape and design of the pool, I'm thinking it should be where the steps are with smaller steps leading down into the pool to keep it symmetrical. The pool builder recommended taking over the lower right corner for it to maintain a swim lane but that throws off the symmetry. Any thoughts on that? Also, any recommendation on the size of the tanning ledge. I was thinking 5-7' by 8'.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    484
    Re: New Pool - Southern New Jersey
    Wow! That looks beautiful. The wait is going to be very exciting. And I can TOTALLY sympathize with this statement:
    Quote Originally Posted by Esloser View Post
    Some call it OCD. I like to consider myself a well informed customer.
    Good luck with the build. Wish I could be of help with a tanning ledge opinion. I'll leave it to members who have one. Keep us updated on the progress. PICS!!! Need Pics along the way.
    25 + year pool owner. Current pool (going on 11th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    You Need: Bleach, a A Test Kit & a Bookmark to "Pool School". Now what's your question?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,294
    Welcome to TFP! I'm so glad you found us. You will love it here. Hopefully you'll check out Pool School and especially this page first and foremost...http://www.troublefreepool.com/conte...ater-chemistry regarding pool chemistry. You can and should maintain your pool yourself. It's easy!
    This is a small thing but I don't have it and it would be an extra cool thing to have. Since you are getting three ColorLogic lights and ProLogic automation (the two requirements), I would also get the Color Logic Network Module. You can use the lights without it and they are cool looking no doubt. You can cycle through the colors and light shows using the "power cycling" method. Which means you press the light button on, then off and on in quick succession to move to the sequentially next color or show. But what the Network Module allows you to do is control everything 100% independently and with timing and movement, etc., the way they were 'really' designed to be used to show off their potential.
    Here is the brochure for it. It plugs in to the lower left side of your ProLogic automation electrical panel into a slot that already has a plastic insert just waiting to be removed and replaced with this module. https://www.hayward-pool.com/pdf/man...OLOR-MODHV.pdf
    The cost online is about $230. If money is not a big object, get a third LED light (two is good, three would be awesome for that pool size) then the movement aspect of the module would be killer!
    Other thoughts, make sure the pump is at least a 2-speed (for energy savings) or consider a VS pump. Others can chime in on whether a VS pump would be beneficial with your spa.
    The salt cell must be the T-15 for your size pool (the largest cell Hayward sells for that). It will be perfect for you.
    Strongly encourage you to go with a robot cleaner versus a pressure side cleaner like the Phantom. I'm sure the Phantom is all that and a bag of chips, but robots have several advantages. Easier deployment (plug in and drop in), no separate booster pump needed (lower electricity usage), you don't have to get wet plugging in the water line each time, etc.) Robots are becoming quite popular. Wish I had one instead.
    What type of pool finish are you going with (plaster, quartz, pebble, etc.)?
    I've seen mentioned frequently here that spa blowers are unnecessary if the spa is plumbed correctly. Others can address this further if you are interested.
    I don't have any particular thoughts on your ledge question but folks here love design that stuff for posters. Maybe they will chime in with some drawings for you.
    Good luck!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,294
    We'd also love to see before pics of your backyard. I can tell you from experience, the more pics you post, the more interest your post/questions will garner. It's kind of our payment (aside from donations of course)...CLICK-HERE-to-Become-a-TroubleFreePool-com-Supporter! Shameless I am.
    I hope your spouse won't miss the time you used to spend with them before finding TFP!
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    Thank you for the welcome and for the ideas! I will definitely check out the module.
    Here are some pictures of my backyard as it is as of 2 minutes ago.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Welcome to TFP- your new addiction! What a great design and amazing yard for a pool! That's going to be gorgeous!
    You got great feedback from bmoreswim, we made many of the changes suggested here. We aren't finished with our build yet, so I have no personal experience to offer, but I love seeing the builds and cheering on others.
    As to your tanning ledge and symmetry, if you put one with a couple of bubblers opposite the spa, it would retain your symmetry. Just an idea
    Looking forward to seeing more!
    Quote Originally Posted by bmoreswim View Post
    I had to laugh at this- it is SO TRUE!
    Hubby-"Are you on your pool site again?"
    Me-"Umm, yeah, just gotta respond to this post real quick..." Lol!
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    Here are my tanning ledge thoughts and would be interested in some feedback:
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Welcome to TFP.
    My pool under construction is same Roman shape as your designs. I don't have a Spa but have put the steps in the center with two small tanning ledges on the sides. You may get some ideas from this. See my Build thread: link in signature below.
    Happy planning & design.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    I actually came across your thread while browsing. Just as a frame of reference, what are the dimensions of your two tanning ledges? Actually, your tile is similar to what we were looking at as well.
    Eric
    Quote Originally Posted by IrwinK View Post
    Welcome to TFP.
    Aug 2014
    NJ
    426
    I would put the tanning ledge opposite the Spa (where I am guessing more of your guests will be)but what about having it come out into the deck instead of having it go into the pool. In other words, instead of taking up space in the pool you would be expanding the pool to include the tanning ledge. If the tanning ledge is in the middle your steps may not get as much use as people may just use the ledge to get in and out.
    I dont agree about the robot - I think a pressure side cleaner is more convenient. It stays in the pool and you generally don't have to worry about taking it out. And you don't have to run an annoying electric cord over your deck every time you want to use it. Some people with robots use caddys to bring it to and from the pool. Seems like a pain to me.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Aug 2014
    NJ
    426
    By the way, if you take my suggestion about the sun deck, consider moving your steps to the left and put them on the corner. That way you will have a longer distance to swim laps and you can put a basketball hoop on the deck where the steps are now.
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    I'll have to ask the builder that one. I'm not sure what expanding the footprint and square footage of the pool would do to the cost. As it is, he's asking for $1k as an addendum after signing the contract. If I add another 50-100 square feet to the pool, I'm guessing he's going to want more than that, but there's really only one way to know for sure.
    I'm not sold on the robots either. to me, they are akin to taking a toaster in the bathtub with me. I know they are probably safe, but that's one of my concerns.
    Eric
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Eric
    Space planned for the steps and the 2 tanning ledges was 5' x 15' It came out a few inches different. Each tanning ledge is approx. 5'x5' and the step area approx 5' wide. Actually came out a few inches more.
    If you need a larger tanning ledge you can put one tanning ledge and the steps on the side. I was thinking of that but couldn't live with the steps and the rail I added not being centered.
    I think tile was called AZ-606.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,294
    If you leave your cleaner in, then I'd agree about a pressure/suction. If you remove it like I do (used only occasionally and don't like the in-pool look) then a robot would be a better choice for me.
    I like GG's thought on the ledge. My main opposition to ledges is the space they take up in the main body of water.
    Aug 2014
    NJ
    426
    My PB was about $15 more a square foot (although a tanning ledge may have been more) and I think $20 more a square foot once I upgraded the pool to a more expensive Plaster (which he was charging $5 per square foot).
    I have my Polaris clean everyday for three hours a day and just leave it in. If there are a lot of people coming over i take it out. It is very easy to take out. I just pull lightly on the cord attached to the pool and wherever the Polaris is, it just comes to me. Then I just unplug it from the pool. But if you are only going to clean occasionally a robot might be just as easy if it's easy to get out and maneuver away from the pool. And a robot may clean better. But I'm happy with the cleaning ability and convenience of the Polaris.
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    PB is checking into pricing of adding the tanning ledge to the outside dimensions of the pool and coming up with some additional designs for me to review.
    Jan 2016
    Mesa, Az
    536
    I couldn't decide between a shallow (10 1/2") ledge and a deep (18") ledge. So I did both, separated by steps. Sometimes when it is cooler out, you want to sit in the pool with your feet in the water but not your butt, like if you are wearing street clothes. Other times, when is is hot, hot, hot, you want your butt and a good portion of your body submerged. I bought a plastic adirondak chair and took depth measurements to confirm . . . by the way mine are both 7' x 7'.
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    How many adirondak chairs can you comfortably fit on the 7' x 7' ledge? I'm looking at a 7 1/2' x 7 1/2' ledge that would be 12" deep.
    Jan 2016
    Mesa, Az
    536
    A group of four around a small drink table is nice. If you wanted to squeeze i think you could fit two rows of three facing each other.
    Go to Home Depot, grab a tape measure and head over to the chair section. Measure our an approximation of your area and start unstacking chairs and arranging them until its full. Then put the chairs and tape back and leave. No hassle, no investment.
  20. Back To Top    #20
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    333
    I like your style. I measured it out in my family room.
    Quote Originally Posted by BigEinAZ View Post
