Results 1 to 17 of 17
Thread: Still have copper issues...
    Mar 2016
    Easley, SC
    380
    I thought the copper issue was behind me since I got it down to 0.2 but I guess thats still enough to cause tinted green hair. Lucky for my daughter its not very noticeable but I need to fix this issue. What does everyone recommend? I originally had over 2.0 when I first opened the pool. I can only assume it was from the previous owner using copper algaecide. I would rather not drain the pool again as it took me over a week to refill half the pool as I am on a well. I have not noticed any major staining in the pool other than a slight shade of tan on the steps but I figured that was from never being properly cleaned. I am open to all thoughts..
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    JoyfulNoise's Avatar
    May 2015
    13,215
    Consistent use of a metal sequestrant should work well enough. Then, as the season progresses, backwash frequently or do frequent small water drains to exchange pool water with fresh water. You can work out a schedule for that which doesn't stress your well's output too much. Then, when the season ends, cease using sequestrant and try to get a new metal reading. You'll need to wait for the sequestrant to break down from chlorine oxidation or else it will interfere with a metal test.
    Matt
    Mar 2016
    Easley, SC
    380
    Re: Still have copper issues...
    Thanks Matt, do you have a recommendation for a sequestrant? Any certain ones work better than others?
    May 2015
    13,215
    MetalMagic line OR Jack's Magic line. Both are used a lot here in TFP so your likely to get the most help if you use one of those.
    Matt
    Snap96's Avatar
    Jun 2015
    Chicago, IL
    39
    I feel your pain...my daughter's hair would turn green all summer last year....this year has been much better. I'm not sure if that's due to the sequestrant I'm using, the amount of backwashing done last and this year, or a combo of both.
    Last year I used Bioguard Pool Magnet Plus, Jack's Purple Stuff, Natural Chemistry Metal Free, and HTH Metal Control. HTH changed the name this year to Metal Stain and Defense and it's the only sequestrant I've used this year. Walmart carries it for around $13.
    From what I've read on this great forum is that sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. Bioguard, Jacks, and HTH are all HEDP I believe.
    Barrier Reef Whitsunday 35' IG Fiberglass...17,500 gallons...Hayward H250 Heater...Hayward Max-Flo XL 1.5hp Pump...Hayward 24" Pro Sand Filter...Hayward Aqua Plus SWG...Taylor K-2006 and K-1004 Test Kits...Built Spring 2015...Use village well as fill water
    Mar 2016
    Easley, SC
    380
    Thanks! I will check those out that you listed. If I am understanding correctly, I will have to add this the entire season to keep the metal separated and over time it will hopefully be flushed out by water replacement?
    It appears the WalMarts in my area do not carry this. I was hoping to be something local I could pick up. Guess I will have to go to Amazon...
    Whats color is Jack's Magic is best for a vinyl pool with fiberglass steps?
    May 2016
    Troy IL
    476
    Quote Originally Posted by joshua5438 View Post
    If you are judging the inventory of your local walmart by their website, don't. Call the store or go look yourself. Walmart's inventory system is a joke at best. If they have pool stuff at your walmart, they probably have this.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    May 2015
    13,215
    Jacks Magic Blue stuff is good for copper and works with vinyl pools.
    You need to add the startup dose at first and then keep up the maintenance dosing all season.
    Replace as much of the water as you can with backwashing and splash out. Collect rain water if you can and use that too. Then, at the end of the season you can taper off the sequestrant and see what the tests results come out as. It is best if the place doing the test uses a total copper type metal test as that type of test destroys any residual sequestrant and measures the true copper content of your water.
    Matt
    Mar 2016
    Easley, SC
    380
    I will check Walmart in person and see. My local pool store only carries Natural Chemistry Metal Free. I purchased that thinking it would be good but now I have read it isnt the best. I will return it tomorrow. I will order the Jack's Magic if I cannot find the walmart stuff.
    May 2015
    13,215
    I wouldn't go too crazy trying to find the "best" stuff. As long as you get some HEDP based sequestrant into the water, you'll be fine. You're not dealing with a huge concentration of Cu as it seems to be more of a cosmetic issue with your daughters hair. Once you get some sequestrant in the water, you should see that effect lessen. Just in case, your daughter might want to rinse her hair with lemon juice when she gets out of the pool and then shower off immediately but use very little shampoo (none at all if possible). A swimming cap would help too.
    Matt
    Snap96's Avatar
    Jun 2015
    Chicago, IL
    39
    I should have added that the Natural Chemistry stuff did nothing last year for me and I would return it.
    Mar 2016
    Easley, SC
    380
    Took it back this morning. Pool store was packed! I wanted to tell everyone in the store to leave and check out TFP!
    May 2015
    13,215
    We have business cards you can print out and pass around.
    Matt
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Aside from all the above pool care talk, I just want to mention that there are shampoos to help remove the green. You daughter might be happy if you surprised her with this...
    ion Swimmer’s Shampoo
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    metal Free is citric acid, not HEDP...good thing OP returned it
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mar 2016
    Easley, SC
    380
    Thanks everyone! Ordering the Jack's Magic today. Thanks for the link to the shampoo also, my daughter is 7, so the green highlight was cool to her at first. haha. You can only see it when the sun hits the right way. I just didnt feel good about buying the metal out and should have walked out when they said it was the same as Jack's Magic. I will also look for the cards to print out and start handing those out. Customers in the store looked totally lost and wondering around. So glad I found this site before I was suckered into the pool store ways.
    May 2015
    13,215
    Matt
