Thread: pH is climbing too quickly...
    Apr 2015
    Charlotte, NC
    19
    Question pH is climbing too quickly...
    I've had my pool for about 14 months. For the first year+, the pH would climb roughly 0.1 per day. So, I would add a little acid every couple/few days to keep it in check. From what I gather, this is normal for a newish plaster pool.
    But for the past week or so, though, the pH has been climbing at twice that rate--about 0.2 per day. I have no idea why this is.
    I'm measuring pH with a Taylor kit, and with a pH meter I bought a few weeks ago. The two of them always agree on the pH reading.
    Everything is pretty much within spec:
    FC: 9 ppm (a bit high, I know)
    CC: 0 ppm
    TA: 60 ppm
    Calcium hardness: 350 ppm
    CYA: 60 ppm
    Salt: 3,000 ppm
    Borates: 50 ppm
    I added boric acid a month ago. It didn't do anything much to the pH at the time, nor for at least the 3 weeks after.
    I haven't been doing anything different lately, other than adding ~6 ounces of Jack's Magic "The Magenta Stuff" every weekend for the past 3 weeks.
    Nothing else unusual is going on, that I can tell. The water looks great. Nice and clear, no stains, etc. What could account for the doubling of the pH change rate?
    Aaaaand... I just realized I've been running the pool's two arcs ("waterfalls"), which can increase pH. I can turn them off for awhile to see if that makes a difference. BUT... I've been running the arcs for several weeks! So, I am still confused!
    10,000-gallon inground pool, Jet Black PebbleTec / plaster
    Hayward S244S Sand Filter
    Hayward Super Pump, 2 HP
    Hayward AquaRite AQR9 / T-CELL-9 ECG
    Polaris 360
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: pH is climbing too quickly...
    Are you running your T-Cell-9 longer than in the past? That causes pH rise too. Between the Salt cell and the Water Fall, those are the culprits.
    Is this 0.2 rise per day like from 7.4 - 7.6? Or more like 7.8 - 8.0? Because pH bounce is not linear, it's algorithmic. Meaning the first 0.2 will occur quicker than the next 0.2 and so on. If you are stabilizing around 7.8, shoot to keep it there. You will drive yourself nuts if you are targeting to keep it in the low 7's.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Apr 2015
    Charlotte, NC
    19
    I turned the T-Cell up a tiny bit a few days ago, but when I say "tiny" I really mean it. Like, less than 5%. It's on roughly 35% right now. (I run the pump 12 hours per day.)
    Yes, exactly--from 7.4 to 7.6. I used to only check pH every couple days or so, and let it get up to ~7.8, then drop it down to ~7.4 or 7.5. Since getting the pH meter, I've been checking the pH more often, because it's so convenient. I guess I happened to notice the quick pH upcurve, and drew the wrong conclusion.
    Thank you!!! Truly appreciate it.
    Polaris 360
