Results 1 to 7 of 7
Thread: Pebble not filled all the way!
    Jun 2016
    San Diego, CA
    10
    Angry Pebble not filled all the way!
    Stayed up this morning to make sure my new pool and spa were filled up to the top completely. It finished at 4:30am. Went to bed. Woke up at 6:30 to find out the spa went down about 1/2 way. PB says that one of the valves is probably turned the wrong way and he may be able to come by today to fix it. I am freaking out that this may affect the pebble in the spa since some of it is exposed now. What should I do?? Will it be ok? Should I hammer the PB? Mayday!
    14-15k gallon (450 sq ft) IG Pool w/ Pebble. Pentair Quad 60 Filter, Intelliflow Circ/Jets Pump, SWG, Solar (300 sq ft), Auto Fill, Easy Touch, LED Lights
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    Re: Pebble not filled all the way!
    Put a sprinkler on it.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jul 2015
    Central Valley CA
    1,109
    you have pictures of the valves and we can figure out how to keep it from draining I think you will be better off refilling. I would push the builder tell them you are worried about developing a ring where the water drained to.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2016
    San Diego, CA
    10
    He knows I'm freaking out about it. He says they need to turn on the panel and do it that way. We did the easy touch deal.
    Nov 2015
    Carrollton tx
    451
    you can also change valves manually - even the electric ones
    they have switch on them
    post a picture here and the smart people will likely be able to give you guidance
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Jun 2016
    San Diego, CA
    10
    Hi all-
    Really appreciate all the help! PB ended up showing up at 8am and fixed the issue. No damage to the pebble! Thank goodness. What a nightmare!
    Feb 2016
    Atlanta, GA
    145
    Glad to hear it's all fixed.
