Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Overfilled pool-consequences?
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Question Overfilled pool-consequences?
    I was adding water to my pool due to normal evaporation but I forgot about it and overfilled it, again. I know I need to backwash as I always have but what a waste of water! What are the consequences of having too much water in the pool? I ask because I have a pond that I'm in the process of cleaning and would like to siphon water from pool to refill the pond this weekend. What do y'all think?
    I should add that we are not in a water conservation area but we are on city water so it's still money down the drain. On the other hand, I normally fill the pond with well water. I don't use well water for the pool because of the hardness.
    Grecian 11,800 gal. IG vinyl, Pentair TA-60 sand filter, 1.5 hp Superflo, built in 2007, replaced vinyl & converted to Intellichlor IC-40 SWG in 2012 after we purchased home. TF-100 Testkit, SWG manufacturer recommends salt levels 2600-4500, ideal being 3400-3500. Polaris 180 vac.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Re: Overfilled pool-consequences?
    The extra water shouldn't throw off your chemistry calculations by all that much. When everyone's playing in the pool and it's too high, water sloshes out through the hole in our skimmer lid. That's about all I can think of.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    I would say not much problem, but your skimmer won't really work properly.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Right, poor skimming is the worst problem. A hose timer from Lowes is your friend.
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Quote Originally Posted by pooldv View Post
    Yeah, I usually set a timer on my phone. Couldn't find my phone tho... Just another ordinary day,LOL.
    I've never even heard of a hose timer before, I'll look for it next time I'm at Lowes. Thx!
    Thanks to all who responded! Such a great help, I <3 TFP!
    May 2016
    Troy IL
    476
    wait, won't overflowing an in ground vinyl liner pool put you at risk of a floating liner? Or at least wrinkles? I set timers and do everything I can to avoid overflowing in my in ground vinyl liner pool due to this. Maybe I'm wrong though.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Quote Originally Posted by camueller View Post
    I hope not!
    ANYONE?! HELP?!
    I'm going to backwash...
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    I'd think it'd take a lot of overflowing to do that. I haven't seen anyone here mention it happening from lots of rain.
    May 2016
    Troy IL
    476
    Our pool was built by the previous owner of my house in 2007 and when I took ownership in 2015 he told me the couple of wrinkles in the wall were the result of a large amount of rain while he was out of town once, and the pool overflowing.
    He's by no means an expert, but there are certainly some slight wrinkles along the wall that you can feel if you run your hand around it. So I'd be interested in hearing from the experts on this one.
    DFW, TX
    24,517
    Pool liner floating is normally from rising ground water. I don't know where the water table is for OP or how much water the hose can put out but it is unlikely.
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Thank you expert! I feel a bit better now.
    Can you tell me what you mean by OP? I'm not positive about the water table this house is built on a bluff. The 'back 40' (lol) drops fast. Not suitable for building on but good for hunting.
    Aug 2014
    Northern IL
    4,615
    I have had wrinkles behind my liner from over-flowing, but the water level was above the liner on the wall and part way up the coping.
    EDIT:
    I TOTALLY forgot to mention that I had a cover on! Sorry!
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I too have been paranoid of over filling a vinyl in ground (more monsoon rains than filling) but you also have to factor in
    the tremendous weight of your fill water pressing against the sides.
    I just hope I never end up with wrinkles as some pointed out.
    Dolphin E10 Cleaning Robot.
    Wow! considering an in-ground vinyl and had no idea it could cause an issue.
    SunCountry
    South Phila PA area.
    Sundance Spa; Chelsea (468 gallons). Former 28ft AGP owner for 20 years.
    May 2016
    Troy IL
    476
    Quote Originally Posted by suncountry View Post
    I grew up in South Texas and rarely saw a vinyl liner pool, it was always gunite and plaster. I had a very negative opinion of them up until recently when I bought a house with an in ground vinyl liner pool. The previous owner would have installed an above ground pool, but the HOA would not allow that. So he went with the next cheapest option.
    I talked myself into own the house with the vinyl liner because I figured when I do have the replace the liner, it'll be a lot cheaper than having a pool replastered, and as simple as my pool is, I think I can probably install it myself. Plus the vinyl has a nice footfeel when you are in the pool. So those are some pluses.
    But if I had the money, and I was installing the pool, I'd get gunite and whatever surface you like on it. The customization is worth it to me. And you won't have to worry about your liner wrinkling.
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    ...don't know where the water table is for OP...
    OP = overfilled pool? I know, lame, just checking.
    38,548
    OP = Original Poster ... that would be you
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Duh, lol! Ah well, learn something new every time I'm on TFP
    Three summers & I'm still such a nube. Then again, I'm a pool genius compared to the rest of this house. Thanks again for your help!
    DFW, TX
    24,517
    Nice work being the pool genius!
  20. Back To Top    #20
    Mar 2015
    US
    122
    I never heard of wrinkles with an overflowing pool. I suppose it might depend on the construction. We have very porous ground (sandy gravel), a 200 foot deep ground water level and a porous poolcrete pool bottom (under the liner). If any water gets behind our liner, it's draining straight out. Even if there were some wrinkles, dropping the water level will allow the liner to be readjusted.
    There are some really crazy customization options with a vinyl liner.
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
