Thread: SWG with Galvanized Pool Walls
    Jun 2016
    Knoxville TN
    5
    I'm doing a DIY pool and bought a kit online but I have a pool builder that's helping me out along the way. My question is when I was deciding on pool walls the manufacturer wanted me to use polymer but the pool builder said galvanized steel all the way because its stronger and it's what he preferred. I didn't The manufacturer came back and said since I was using salt water they recommended the polymer so I asked my pool builder and he said he's done pools for 20 years and never seen an issue so I went with the galvanized steel and I'm halfway through the install. This is concerning me because every pool manufacturer website I look at says no salt with metal walls is this true?
    My 2016 pool build, 18'x36' (19k gal) 3-1/2x5, inground Bayview 28mil vinyl liner with galvanized steel walls - pump: Hayward EcoStar variable speed - filter: Hayward SwimClear C2030 Cartridge - saltwater chlorination: Hayward AquaRite 25k gallon
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: SWG with Galvanized Pool Walls
    Welcome to TFP and congrats on the new pool!
    It will be fine. There are lots and lots of people with steel pools and saltwater.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    All pools are salt water pools, it is a very low amount of salt, between 1000 to 1500 ppm normally, SWG pools are at about 3500 PPM.. the ocean is at 32,000 ppm
    It may take a year or 2 off the life of the steel wall, so instead of 50 years you get 48
    It can be a problem if there is a leak, say on the skimmer, that you let leak for 5 years but its going to be the same amount of damage with or without a SWG...
    I hope this helps
    stick around and check the site out, what a perfect time to find a better and cheaper way to take care of your pool
    Jun 2016
    Knoxville TN
    5
    I'm kind of freaking out about this so I apologize but everything I'm reading is it will cut the life of the pool from 20-25 years down to 10-15 years because of corrosion. I'm wondering if anyone on the board has had this installed for more than 10 years without any issues. Also why are pool manufacturers pushing this so hard if the polymer are only about a $1000 adder?
