Results 1 to 7 of 7
Thread: Pump Run Time
    Jul 2015
    Sarasota, FL
    43
    Pump Run Time
    Pool is working perfectly with chlorine TFP. Added Borates and love the feel and chemistry stability now that everything is "just right".
    My final area of curiosity now is pump circulation run time. Our pool is enclosed in our screened patio and use Hayward Ultra pool vac so debris is really not a factor from a skimmer point of view. So what are the parameters that dictate minimum pump circulation run time. I understand pump electric demand is a significant consumer of electrical dollars so I want to do right by the pool but save money if I can. Right now the pump runs from 8 am to 6 pm.
    Thanks in advance.
    Floridarandy
    15000 gal in-ground rectangular concrete/pebble-tech pool. Hot Springs Prodigy 325 gal spa.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pump Run Time
    Check out this article in Pool School: Pool School - Determine Pump Run Time
    Your pool likely only needs 4 hours of circulation per day. Do you have a timer on the pump? Is it single speed, two speed or variable speed? Would help to list your pump specs in your signature.
    I personally run my single speed, 1 HP pump 6 hours per day. 3 hours midday and 3 hours late in the evening. A salt water chlorine generator would also significantly impact your pump run time needs.
    Isolated Spa - 345 Gallons
    Jul 2015
    Sarasota, FL
    43
    Re: Pump Run Time
    Thanks for the link. I'll post pump details when I get home but its definitely a single speed and I believe 1 hp. I do have a timer so that would be easy to set.
    XprtCombatNinja's Avatar
    May 2015
    Mount Clare, WV
    30
    Re: Pump Run Time
    I too wonder about this? I currently have my timer to turn on/off every three hours so I go through 8 cycles a day. Last year I had it on/off every four hours. I also keep my pump set on high. Any advice someone could add to this? Is this too much?
    24', Above-ground vinyl, 14,000 gallon, 1HP 2-speed Jacuzzi Magnetek pump, Jacuzzi Brothers CFR75 cartridge filter, Tork EW103B timer, Hayward 100ID gas heater, Junior Pool rover T robot
    Feb 2014
    Central Minnesota
    5,080
    Re: Pump Run Time
    If it's on/off every 3 hours, isn't that the same as on/off every 4 hours? Either way, it's 50% of the time. 12 hours per day is likely overkill. Only run as much as it takes to keep the pool skimmed of surface debris, at least 4 hours per day.
    How many cycles and how long are they?
    Jul 2015
    Sarasota, FL
    43
    Re: Pump Run Time
    Here are the pump details.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    Re: Pump Run Time
    I ran mine 3 hours a day and after a suggesting from Mark (mas985) i'm down to just 2 hours a day.
    pool is mostly covered with the bubble cover so skimming isn't going on unless the cover is off.
    seems to be just as clear so far.
    on weekends I take the cover off and run it longer and while swimming to keep the surface clear.
    Dolphin E10 Cleaning Robot.
