Results 1 to 8 of 8
Thread: RAIN RAIN RAIN
    Mar 2009
    Macon Ga
    77
    RAIN RAIN RAIN
    We are getting a ton of rain and is there any reason to shock the pool if the FC is holding right where it is suppose to be and the CC is 0? Check it in the evening and early morning and it is stable at 5. PH is drifting a little but I did bring it down to 7.5 and everthing else is good for now. Thanks
    18X38 Grecian 26000 gallon In Ground Vinyl. Goldline AuqaRite SWG with a 1.5 HP Pentair Pump. Triton 2 Sand Filter Two main drains with 4 main returns with 2 more returns on the swimout and two skimmers. Polaris 380
    Re: RAIN RAIN RAIN
    No, no need to shock as long as the FC level is holding.
    Jun 2008
    Carrollton, GA
    88
    Re: RAIN RAIN RAIN
    I am having the same problem with the rain. I just vacuum and add bleach as needed, and check levels often. So far have only added bleach and a little cya as the rain has diluted cya.
    Susan
    18x33 AGP, BAQUAPURE 200 lb sandfilter, 2 1/2hp Workhorse pump (2 speed)
    30,426
    Re: RAIN RAIN RAIN
    Interesting posts. It seems to me that rain alone has little affect on pool water chemistry. It's when the deck is sloped incorrectly (common) and run-off water is allowed to get into the pool that the effects are much more dramatic.
    Re: RAIN RAIN RAIN
    Ha ha, it's raining here in Central Arkansas as we speak. We are expecting 4". I have a temp pool solution going on before we get our big one installed later this summer or early fall. We went with the 18' x 48" Intex. I have to admit that it is a pretty nice set up, except for the pump. We got a bigger one based on reviews. It works like a champ. I am using the BBB method and so far so good. Only been up since Wednesday, May 20.
    I was wondering what effect the rain would have on it. Glad to know that it doesn't have a big effect on it.
    I can tell you one thing, I will be looking for some bulk baking soda, borax and bleach.
    Dec 2007
    Switzerland, Fl
    24
    Re: RAIN RAIN RAIN
    Tons of Rain in Florida any idea why it makes my water cloudy?
    FC4.5
    TC 4.5
    TA 50
    CYA 40
    PH 7.4
    Viking Cancun 16X35, Pentair Clean and Clear Cartridge Filter, Pentair 1.5hp whisper flow,
    SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Re: RAIN RAIN RAIN
    Quote Originally Posted by cval
    FC4.5
    TC 4.5
    TA 50
    CYA 40
    PH 7.4
    Are you running your SWG? If yes, then your CYA is too low. The TA is low for SWG or LC/bleach. What are your salt & CH levels?
    You're done SLAMing when:
    Dec 2007
    Switzerland, Fl
    24
    Re: RAIN RAIN RAIN
    Quote Originally Posted by Butterfly
    FC4.5
    TC 4.5
    TA 50
    CYA 40
    PH 7.4
    Had to do a lot of draining with the Rain that brought down CYA level down.
    CH 250
    salt 3100 strip
    2300 salt generator need to add salt
    SWG
