Thread: Hazy/dull pool
    Feb 2016
    CYPRUS
    56
    Hazy/dull pool
    The larger of the 2 pools I look after has clear water but it is dull/hazy, here are my latest test results. I am treating it exactly as I do my own pool but not sure why I have this type of "cloudiness". When I refilled the pool I did a deep clean of the sand filter before putting it back in operation, any advice much appreciated. The water was sparkling clear for the first week...
    FC 3.8 (ADDED BLEACH AS PER THE CALCULATOR)
    CC 0
    PH 7.3
    TA 89
    CYA 49
    10300 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    9500 Gallon vinyl pool, 0.75 Kripsol pump, glass filter, Pool Exact EZ photometer tester.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Hazy/dull pool
    Generally a pool gets hazy or cloudy due to an algae outbreak. The minimum FC for a CYA is 4. Pool School - Chlorine / CYA Chart If you regularly go below that, algae can start.
    Performing an OCLT Pool School - Perform the Overnight FC Loss Test (OCLT) can confirm the need to SLAM. Pool School - SLAM - Shock Level And Maintain
    Feb 2016
    CYPRUS
    56
    Re: Hazy/dull pool
    Thanks for the reply, I will do as you suggest
