Results 1 to 9 of 9
Thread: Question on child's eye burning after swimming
    Jul 2015
    Poway, CA
    58
    I hope I can post this here. My question is why does my child's eyes burn after swimming (no goggles worn)? I have goggle for her but she forget to wear them. My numbers are all in check.
    Saltwater
    Salt level 3100
    FC 5
    CC 0
    TC 5
    PH 7.6
    TA 110
    CH 425
    CYA 40
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    Aug 2014
    Northern IL
    4,615
    Re: Question on child's eye burning after swimming
    What is your CC level?
    38,285
    Do they rub their eyes every time the head comes out of the water? There was a post explaining that the rubbing causes more irritation than the chemistry.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,247
    Your FC number is more meaningful along with your CYA number. CC should also be included. Effects are usually attributed to pH out of range, high CC and lack of salt in the pool.
    This article was a life-changer for me. I love to swim underwater and got itchy burning eyes from swimming anywhere, including a variety of pools, lakes and the ocean. It was not easy to teach myself not to rub; I had to keep my glasses by the pool and put them on to stop me. But once I learned it, now even shampoo has stopped my eyes from being red, other than for the instant I get some in my eyes. Anyway, food for thought. Certainly if it persists, you should seek advice from a physician.
    Swimming Teaching: Bloodshot Eyes After Swimming or Sore Eyes From Swimming?
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jul 2015
    Poway, CA
    58
    Quote Originally Posted by MarianParoo View Post
    CC 0
    salt 3100
    Build in 1969
    Water From City
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    The most important number is missing. CYA buffer the chlorine and the chlorine level is set based on the CYA level and the FC/CYA Chart.
    Jul 2015
    Poway, CA
    58
    Quote Originally Posted by pooldv View Post
    Sorry CYA 40
    Build in 1969
    Water From City
    TF-100 Test Kit
    DFW, TX
    24,491
    Ok, that is high enough to make FC of 5 just fine. But, it is too low for an SWG pool. It would be good to raise it to 70 or 80.
    Jul 2015
    Poway, CA
    58
    [QUOTE=pooldv;1069154]Ok, that is high enough to make FC of 5 just fine. But, it is too low for an SWG pool. It would be good to raise it to 70 or 80.[/QUOTE
    I am trying to get there as I just converted to saltwater. I will add some more liquid stabilizer.
    Thanks for all of the help.
    Build in 1969
    Water From City
    TF-100 Test Kit
