Just got my Taylor K-2006 test kit! Looks like TA is high with low PH
May 27, 2016
34
New Jersey
Pool size: 16x32 Vinyl Liner, 20,000 gallons
Pool temp: 82 Degrees
FC= 3.6
CC= .4
pH= 7.1
TA= 180-190
CH= 110
CYA= 90
It looks like TA is high and my pH is a little low. Correct me if I'm wrong, from my understanding, I can't raise the pH without raising the TA.
Any advice is appreciated.
Thanks!
Your CYA is high so you need to drain some water. Depending on the TA of your fill water, draining some water may take care of your TA issue.
