Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Pool uprights not level.
    Sep 2015
    West Olive, mi
    35
    Hi, I need some advise. My pool was installed last week, it is a 30 ft above ground Quantum(Sentinelle) Aqualeader. I sent pictures to the company we bought it from and they acted like it can be fixed and the pool is totally safe to swim in. I am unsure about that. Today the installer called and asked what was going on and I told him the uprights look like they are leaning into or out of the pool and he acted like it is a problem with this particular pool and not able to be fixed. I will attach pictures in a minute if I can figure it out.
    30' Aqualeader AG Pool
    Hayward Sand Filter
    Sep 2015
    West Olive, mi
    35
    Re: Pool uprights not level.
    Hayward Sand Filter
    Sep 2015
    West Olive, mi
    35
    Hayward Sand Filter
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    So the manufacturer says it's a bad installation and the installer says it's a manufacturing defect.
    I'm calling it a bad installation. I'm an expert because I did it myself with our 20' Intex, two years in a row. It's easy to do and easier to spot- they should have spotted it before they filled it. If they spotted it after they filled it, the easiest way out would have been to apologize for the delay while they drained it and fixed it. Now they're trying to pretend that the pool kit left the factory with posts that weren't plumb?
    Ask your installer for his company's liability insurance information. Explain that you're going to have your homeowner's insurance agent inspect the pool because you worry that they may deny any pool related claims after they see it.
    And then if it's not fixed, do it. You paid for a pool installation and I don't see that it's finished.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Sep 2015
    West Olive, mi
    35
    Thank you, the installer said the day of the installation that they should not even be selling these pools due to broken parts.
    The company we bought it from said it could be fixed by the installer, but the installer acted like it is a manufacturing defect.
    I will definitely do what you said about the liability and the insurance. The pool place stated that the uprights could be taken off of it and it would still hold the water, which I am pretty sure that is a tall tale.
    Hayward Sand Filter
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    The installation crew obviously didn't measure to make sure that the bottom track was perfectly circular after they set the wall up. That is an important step as when installing the wall the bottom track is going to get all out of round.
    They should have trued up the diameter and they failed to do so which is why there are uprights going all different directions.
    They definitely need to come back and drain it and do it right. I'd also push for them to pay for the water since it's their fault it has to be drained and redone in the first place.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Sep 2015
    West Olive, mi
    35
    Thank you for all the great information. I will keep you updated, the installer is coming on Saturday.
    Hayward Sand Filter
    Casey's Avatar
    SW PA
    10,423
    I agree with Jamison but... I have a question. Is the pool full in all these pics or just the first picture?
    The pool is out of round. The pool installer is an idiot and taking the easy way out by blaming a company that had nothing to do with the installation of this beautiful above ground pool. Don't buy the BS.
    Sep 2015
    West Olive, mi
    35
    The pool is full in all of the pictures.
    Thank you for all your help. I will update tomorrow after he is here.
    Hayward Sand Filter
    Sep 2015
    West Olive, mi
    35
    I do have a quick question about wrinkles. We have a few and it is a flat bottom pool. Also when a new pool is installed on fine mason sand is it squishy on the bottom. Thanks everyone
    Hayward Sand Filter
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Wrinkles: being out of round will definitely create more wrinkles than if it was perfectly round. Wrinkles for happen but should be very far and few between when it's perfectly round. Fewer if it's a beaded liner as they are slightly smaller and stretch into place.
    The sand bottom will be squishy if it is several inches deep and was dry when they installed the liner. It won't really ever pack much until all the weight of the water is pressing down on it and even then it might still shift some. Damp sand will pack down a little bit better.
    Sep 2015
    West Olive, mi
    35
    Thank you so much Jamison. It is a j hook loner so I am not sure if it is beaded.
    Hayward Sand Filter
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    J hook liner is also cut slightly smaller than the actual pool dimensions and will also stretch into place as it fills and should be for the most part wrinkle free.
    Sep 2015
    West Olive, mi
    35
    Thank u so much. That is what we were thinking. waiting for the installer, so..
    Hayward Sand Filter
    Sep 2015
    West Olive, mi
    35
    About the wrinkles
    Hayward Sand Filter
    Sep 2015
    West Olive, mi
    35
    Ok, they r saying we should not have put a pool on disturbed ground. I am about fed up.
    Company will do whatever to fix pool, but will not refund or take the pool back.
    Hayward Sand Filter
    Sep 2015
    West Olive, mi
    35
    Pool installer is saying no pools uprights r exactly plumb or level. They will always be a little off.
    Hayward Sand Filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    All above ground pools should be installed level and plumb within 1". It should not be obvious that it is off when you look at the pool. Does the installer work for the place where you bought the pool or is he an independent contractor?
    And what do they mean by "disturbed ground"?
    Love TFP? Become a
    TFP Supporter!
    Sep 2015
    West Olive, mi
    35
    Thank you. We are using a level and they are not between the two middle bars, what would within 1" look like.
    We had some trees and the ground was dug down to get the roots out and then the ground was replaced and smoothed.
    Hayward Sand Filter
  20. Back To Top    #20
    Sep 2015
    West Olive, mi
    35
    And we used a compactor.
    Hayward Sand Filter
