Thread: Sand filter deep clean
    jmcdtucson's Avatar
    Jun 2014
    317
    After two years, I finally took the plunge and deep cleaned it. All I can say is wow!
    This year the mesquite tree west of the pool has been raining pollen down on the pool and clogging the filter. Tried filter savers in the skimmer but those just get clogged in about 15 minutes.
    The deep clean did wonders for my water flow.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Jun 2012
    western NY
    1,560
    Re: Sand filter deep clean
    Wow, That is almost another layer of filter material on the sand.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2013
    Buffalo, NY
    80
    Not sure if you did this or not, but I go one step further and remove the 2 phillips screws on the grey piece and remove that entirely. There is an awful lot of stuff that gets inside that as well. Once removed you can hit it with the hose and really get it cleaned up.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
