Thread: Clorox Bleach Packs
    brysclar's Avatar
    May 2015
    Tampa, FL
    23
    Clorox Bleach Packs
    Has anyone tried using these in place of liquid chlorine? I just heard about them on TV. I know they dissolve fast, but I don't know the actual chemistry involved. I thought it might be easy to throw one in the skimmer every couple days... Thoughts?
    10K Gal IG Freeform Fiberglass Pool
    1.5 HP Centurion Pump
    Pentair CC100 Cartridge Filter
    Hayward Automatic Pool Cleaner (model unkown)
    38,301
    Re: Clorox Bleach Packs
    They are dichlor (add CYA) and are actually a much lower % of chlorine than normal pool dichlor. They are mostly salt actually.
    BTW, TFP does not recommend "throwing" any chemical into the skimmer.
    EDIT: I assume what you are asking about is the same as the Clorox Bleach Crystals? But just in a small pack form?
    brysclar's Avatar
    May 2015
    Tampa, FL
    23
    Yeah, I figured as much. I won't be throwing them anywhere after all. Thanks.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,253
    I haven't and wouldn't add it to my pool. The description is linked below.
    https://www.thecloroxcompany.com/dow...2015-05-21.pdf
    Looks like a form of dichlor with a bit of washing soda (soda ash). It would raise FC and will add CYA to your pool, along with raising pH and TA.
    Best source of chlorine for your pool is chlorinating liquid because all it adds is free chlorine and salt. That or you can make your own FC with a salt water chlorinator.
    It's fascinating that Clorox would market stabilized chlorine as being better for cleaning. The CYA would reduce the sanitizing power. But I suppose it's more gentle so you could use more of it. I don't like light beer either
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    brysclar's Avatar
    May 2015
    Tampa, FL
    23
    Thanks for the link. I couldn't find that.
