Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Mystery object found in pre-pump basket: Any ideas what this is?
    Jul 2012
    California Central Coast
    74
    I keep finding these in the basket that is just before the pump (not the skimmer basket). I have found about three of them. They appear to be made of graphite and have a white residue on both sides that I'm not sure what is made of (epoxy maybe?). They break very easily, are very light, but they do not float. They are slightly rounded. I haven't found them anywhere else. I can't for the life of me think what this came from. Anyone know what this is or if I should be concerned? Thanks in advance!
    Test Kit: Taylor K-2006
    Pool:In ground/Pebble/16,000 gal/Cartridge Filter/Pool Built appr. 1995-2000
    Casey's Avatar
    SW PA
    10,444
    Re: Mystery object found in pre-pump basket: Any ideas what this is?
    I have no idea what it is.
    Jun 2012
    western NY
    1,560
    No idea either
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,490
    Are they always the same size? How far from the pool is the equipment pad?
    NOT in skimmer basket (which is right by the pool correct?) but in the pump basket (sitting on the equipment pad)...........how may have you found?
    How big is your pipe? 1.5", 2.0" ???
    Kim
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Do you use an automatic pool cleaner?
    Love TFP? Become a
    TFP Supporter!
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    432
    looks like half an oreo! if it breaks easily, it is not likely epoxy. my first thought was some kind of debris left over from installation but i see this is not new. how recently did you start finding them? i'm guessing recently since you just asked. nothing upstream of the basket but pipes from skimmer and/or bottom drains? and these could not get through any bottom drain openings, correct? If that is the case, i'm pretty sure your concern is that something underground is deteriorating but i also have no idea what those could be.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    Jul 2012
    74
    Quote Originally Posted by kimkats View Post
    Kim
    Correct: skimmer basket is by pool, but they haven't been found there. In pump basket on equipment pad; yes. I have found about three (some were broken into pieces so I am estimating). Pipe is 2" I think. Equipment pad is about 20 feet from pool. They are always the same size; I think. As I mentioned, some of them have been found in pieces but the pieces appear to fit together to be about the same size and shape as the one I have in the pic.
    Quote Originally Posted by zea3 View Post
    They are definitely made of either graphite or carbon. They streak and feel just like pencil lead or charcoal.
    I do use an automatic cleaner, yes. But they have been found when that wasn't running.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    How do you clean the pool? Vacuum, cleaner etc.?
    Jul 2012
    Tallahassee, FL
    30,490
    Toys???? Children??? Look at your cleaner REAL good to make sure it is not getting stuck in the pipes. Oh wait back to what kind of cleaner do you have?
    Love me some mystery and puzzle solving!
    Kim
    Jul 2012
    74
    Kim
    I use a hayward automatic pool cleaner.
    Jul 2012
    74
    I looked at the pool cleaner and the intake hole is too small to suck these up without crushing them, so I don't think it is coming from there.
    Jul 2012
    Tallahassee, FL
    30,490
    S it HAS to be getting in from the pipes between the skimmer and pump basket! That does not leave much to work with. How far between finding them has it been? All together? Several days? How many have you found?
    Kim
    Jul 2012
    74
    I have found about three. This first time I found two at once. This last time I found 1 and it was about a week after the first find.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Must have been left in the pipe from the pool builder is my guess. Why it shows up now is weird. Did you just get a new pump with better flow?
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2012
    74
    Quote Originally Posted by wjr75 View Post
    The only changes I have recently before this occured was I put in new cartridge filters, so yes; the flow probably improved some. I also added borates to the pool. Maybe the acid I added to counter the borates knocked them loose? Maybe the borates somehow knocked them loose? I followed the instructions on this board precisely when adding the borates and acid (poured in half the acid very, very slowly in front of a jet, put in half the borates, brush, repeat, etc.). Everything went picture perfect; PH came out perfect, TA, borates, all perfect.
    No idea what they could be. Here are a few tests that might be helpful:
    1) Soak a piece in acetone or MEK to see if it dissolves.
    2) Soak a piece in muriatic acid to see if it dissolves.
    3) Try a magnet to see if they are attracted by a magnet.
    Support the site
    SW Indiana
    9,199
    My only idea as to what they could be is an old piece of cushioning foam from something that sits outside. That stuff gets a crumbly, dusty consistency after years of sun damage. Stil doesn't explain how they got into the plumbing.
    Apr 2009
    Central Minnesota
    74
    Just a wild guess: electrical box watertight knockout plugs (or something like it). The rubber decomposes from the chlorine and becomes like graphite, and it leaves a black mark. The white on both sides is what is left of zinc washers, again what is left after being eaten by chlorine. Can you tell if there may have been a post in the center? May have been in the return lines a very long time, and your increased flow was just enough to get them to move out of the return lines. Again, just a wild guess.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
    Jul 2012
    74
    Well, and update; if it will help at all. Look how many I found today!
    http://watercolortutor.com/wp-conten...ry-bunches.jpg
  20. Back To Top    #20
    That’s weird. It looks like the black pieces were glued to something. Try the solvent tests.
    Support the site
