Results 1 to 7 of 7
Thread: Removing Iron From Pool
    Apr 2013
    Sacramento, CA
    2,769
    Homeowner in Elk Grove CA needs help. High Iron in pool.
    Oct 2010
    michigan
    284
    Re: Removing Iron From Pool
    First remove the car, lol
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    JoyfulNoise's Avatar
    May 2015
    13,232
    That's NOT what we meant by SLAM'ing your pool....
    Matt
    Oct 2010
    michigan
    284
    Serious note, you need a crane to lift that car straight out so you dont damage your pool.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    From the looks of,the water it needed a SLAM!
    Support the site
    Apr 2013
    Sacramento, CA
    2,769
    Tim I think the SLAM is completed
    Jun 2014
    15,192
    Nothing a little "pre-filtering" can't handle.
