Results 1 to 7 of 7
Thread: First test with TF100
    Jun 2016
    Ozark, MO
    22
    Just competed my first TF100 test.
    FC: 6
    CC: .5
    OTO showed higher than 5
    pH: 7.5
    Alkalinity: 100-110
    CYA: 50
    CH: 175
    Time to SLAM and clear up that water?
    Also wanted to add that the magnetic speedstir is great and worth the money.
    Adding signature
    Pool Size: Round AG 18500 Gallons(27' x 52'' Deep)
    19'' Pentair Sand Dollar SD40 1.5HP Pentair Dynamo Pump
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: First test with TF100
    That looks pretty good. If the water isn't crystal clear, yes a SLAM is in order. With those numbers it can't be off much. Picture?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Ozark, MO
    22
    So it had 0 chlorine 3 days ago. There's also sand from the old filter I had to replace that seems to be collected in the middle.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    That's not bad at all. Fill in the pool details including pump filter in your signature and you should be crystal clear in not that long.
    Jun 2016
    Ozark, MO
    22
    The mobile version keeps removing my signature anyway here it is
    Jun 2016
    Ozark, MO
    22
    Added two and a half gallons of 10% few hours ago and just tested.
    FC: 21
    CC: .75
    I guess that means there's not much organic left in there and it should clear up shortly?
    Not seeing much CC. Doing the overnight loss test in the morning.
    Adding signature.....
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Quote Originally Posted by JosephBarker View Post
    I checked the show sig box for you. It needs to be checked on each device, under the text box, one time. It should stay checked now.
