Thread: New plaster pool - when to adjust PH?
    Jun 2013
    Broken Arrow, Ok
    19
    I've read the pool school and plaster startup but can't seem to find when you adjust the PH? Do you wait 48 hours like the rest of the chemicals or right away? We are doing a traditional startup.
    Plaster pool
    12,000 gallons
    SWG
    12,000 gallon SWG - IG Medium grey plaster - Water Sheets, Spillover Spa and 28ft x 4 ft tanning ledge
    Hayward High Rate Sand Filter - ProSeries - 2 pumps - 1 variable speed, 1 two speed
    Hayward Heater - Hayward Pro Logic Automated Digital System with wireless remote
    Pool build June 18, 2016 - TF-100 Test Kit with Speedstir - Hayward SharkVac
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: New plaster pool - when to adjust PH?
    Right away. And often, it'll be a battle for many months.
    Pool School - Start-up New Plaster
    No matter what start-up procedure is used, your pool will consume a lot of acid during the first 6-12 months as the plaster finish continues to cure. It is important to test your pH daily and do not let it climb above 7.8. Be sure to continue to brush the pool at least weekly during this period.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2013
    Broken Arrow, Ok
    19
    Thank you so much!
