Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: New 12 x 24 doughboy desert spring with deep end
    I will start off by saying that I say deep end lightly as they did the dig yesterday and the "deep end" area is not very large.
    So my wife and I went back and forth for a couple of years about getting a pool. We looked at in grounds and with the way my yard is set up it would have been pushing 45-50 thousand after retaining walls and landscaping.
    We decided on an above ground as we go to the beach most weekends anyway and wanted something at home so my in laws will have something for the kids to do while we are at work.
    I bought everything out my self and seperate. I bought the pool and equipment direct. Only thing I have not purchased yet is the heater as I am cheap and am waiting for a used one on craigslist for a good price
    We purchased a SP15922S 2 speed hayward pump, a S210T hayward Filter and an aquatrol rj SWG as we used salt before in an intex and loved it.
    Our actual pool install is slated for July 5th and 6th unless they get a cancellation. Yesterday they did the dig so at least that's done. I will have to add a small retaining wall but I can do it myself so no big deal. The week after the pool we are getting stamped concrete installed and after that a deck around some of the pool.
    I'll update this as we go. Still have a lot of wood to chop from the tree we took down but that's good exercise . We are excited to say the least!
    Does this deep end even make a difference to anyone that has a similar sized pool?
    Oh. And the tft-100 kit, salt water kit and mixer have been on the shelf for at least a month!
    Thanks
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Re: New 12 x 24 doughboy desert spring with deep end
    Congratulations on getting started (and already having your kit!)
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Thanks so much. We are excited. Anyone that can chime in on this so doughboy with deep end I would appreciate the feedback
    Thanks
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,579
    HI! I am just now seeing your thread.
    Just how big is that "deep end"? It looks kind of small. More like it would be a trip hazard and dirt holder rather than deep enough to "dive" into. What is your thinking on this? It seems as if it should be a "deep END" instead of a deeper hole. Just my thoughts.
    Kim
    Kim
    E are not making a diving end. Just a spot where the kids can do some cannonballs. I checked the dig spec per doughboy and it is ecaxt based on needing 30" ledges around the deep end. We are limited to a 12' wide pool based on set backs for the Township.
    Jul 2012
    Tallahassee, FL
    30,579
    Sweet! That makes sense. I just learned something! THANKS! I bet the kids will love it!
    Have you done a search on here for you brand of pools? They might not notice your thread but be willing to answer questions if you send them a PM.
    Kim
    I have but not specifically for the deep end except everyone says to get it. I'll take a look
    Installed a 2.5 x 6 foot concrete equipment pad today. I called the pool guy and just said to stub the inlet and outlets and I will plumb the rest. I just don't trust they will do it right. At least I won't have a far run from the gas meter
    Pool install is supposed to start tomorrow. Calling for some rain so we shall see.
    I threw the equipment on so I start plumbing. More pics soon
    Jul 2012
    Tallahassee, FL
    30,579
    Make sure to use sch. 40 pipe, lots of unions and valves for future maintenance and work on the equipment.
    Kim
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    And all Jandy Neverlube type valves - not the straight across plastic handle type that are so attractively priced.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Already bought! In my she'd waiting for me. It's 1130 and pool builders still here. They are going to try finishing tonight. Another crew on saturday for the hard plumbing and electrician on sunday.
    Jul 2012
    Tallahassee, FL
    30,579
    11:30 at night???? Please tell me you are going to go over their work with a fine tooth comb. All I can think of is how tired they must be so.......mistakes or shortcuts could be made.
    Kim
    I was out there until 1245 am with then. I'm in construction management and these guys were very meticulous. The foreman was phnomenal. They will be back today to put up the walls. They basically got the buttress set with the pressure plates the the bottom rails. Very impressed! We had flood lights set up so it was like day time. Lucky I have nice neighbors!
    Aug 2015
    Cypress
    1,679
    Woah!! Until almost 1:00 in the morning? That is dedication to a time line!!
    Another late night. They were here till at least midnight as me and my wide went to bed. Liner is in and about 2' of water above the hopper is in. They lead a mark below the skimmer for us to fill to. I'll get more pics tonight
    Jul 2012
    Tallahassee, FL
    30,579
    You will be swimming this weekend! NICE! after you catch up on your sleep that is! LOL
    Kim
    Haha. Electric not coming until Sunday. Once they get skimmer hooked up on saturday is ok to test the water to see if anytging is needed before adding salt?
    Jul 2012
    Tallahassee, FL
    30,579
    I would test the fill water NOW so you can have what you need on hand. Here are some links for you when staring up and running a pool with TFP:
    Print these out:
    Bookmark these:
    http://www.troublefreepool.com/calc.html
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    Kim
  20. Back To Top    #20
    Thanks for the links! Since I am going saltwater do I need to avoid any of those links?
