Results 1 to 10 of 10
Thread: Pump Motor Overheating and Shutting Off
    Jun 2016
    Warner Robins, GA
    6
    I am new to this forum but had to do something because my local pool place is baffled. I'm working on the third replacement motor by the way.
    I have a Century HSQ125 motor(1.25 HP/SF 1.0). The pump is a Pentair SuperFlo High Performance 350097.
    The motor will run for only 90 seconds or so and shutoff and comes back on after it cools off.
    Wiring was checked and everything checked out good.
    I came across this site while googling and saw someone that had the same problem, but can't find it now and don't know if their problem was resolved.
    Please Help!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump Motor Overheating and Shutting Off
    Welcome to the forum!
    So is this the third motor in a row? The brand new motors are shutting down? Or is this an older motor?
    Mark
    Jun 2016
    Warner Robins, GA
    6
    Third motor in a row within a month!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Have you double checked the wiring for 230v vs 115v? (unlikely given it runs 90 sec)
    It could be something wrong with the wet end. I looked up the 350097 and it does appear to be the correct motor size but if the load is higher than the motor rating, the motor will shut down. One thing to try is to open the pump lid and let the water drain out. Then run the pump (without the lid on) and see if it shuts down in 90 sec. If so, there is an obstruction somewhere in the wet end. If it doesn't shut down, then you may need a larger motor. But before you do, check the impeller part # and post here.
    Mark
    Jun 2016
    Warner Robins, GA
    6
    I will share this with the pool maintenance guy. They did check the impeller prior to the second replacement and said it checked out good. I hope they can get this figured out because it can't be doing its job very well not running consistently.
    The two jets near the stairs were making an odd knocking noise after this motor replacement...
    Jun 2016
    Warner Robins, GA
    6
    OK, wiring checked out. Electrician confirmed correct voltage and amps... Pool store is giving up on me! I called a different pool store and she took all my information. When I gave her the 350097, she said she needed the actual part number which is Pentair part number 340040. She said that is a 2 HP pump and that the motor is 1 HP and that is my problem. Can someone confirm this also?
    mas985's Avatar
    Pleasanton, CA
    11,741
    That could be the problem but when I looked up the 350097, it showed that same motor you had. Does the impeller have a part# stamped on it. That is the only way to tell for sure unless you have the old motor.
    Mark
    Jun 2016
    Tampa
    62
    Third motor in a row within a month? Wow.... I'll agree that it sound like a load problem (wrong impeller for the motor).
    Jun 2016
    Warner Robins, GA
    6
    Pool store is coming back out Monday to check the impeller and install larger motor if that's what it needs. I hope it is actually so I can get the pump working properly!
    Jun 2016
    Warner Robins, GA
    6
    Finally working like a champ! Pool store installed a 2 HP motor and running great!
