Thread: AGP Bonding
    Mar 2014
    Louisiana
    4
    AGP Bonding
    Moderator note - Moved from here: Bonding an above ground pool - Page 2
    I would like to ask a really stupid question, because that's what I'm here for (lol), and before I do that, I want to really compliment everyone in this thread for some wonderful information as we just had an above ground pool installed 15'x26' with a wooden deck and plastic ladder (so no touching of metal in and out of the pool).
    Stupid question: Ok... so if I do all the work with the #8 wire "everywhere" around the pool etc.. as described in this thread, what is to stop the installed bonding protection from working in REVERSE should the highly unlikely event of lightning striking 5 to 10' from the pool wall and hitting a tree or the ground itself?? In either case (lightning hitting the tree or the ground itself; yeah I know... really unlikely; but just asking for educational purposes) could the electricity of the lightning travel from the #8 grounding system through the ground and back up INTO the pool water??? ..... now I said this was a stupid question... lol... its very unlikely this would happen and even more unlikely people would be swimming during a lightning storm because usually at the sign of this people get out of the pool. I guess I'd have to know how far lightning can travel through "Earth" ground (just dirt in this example).
    It just occurs to me though that while the main intent is to protect everyone in the water or "touching the water" that it could be possible for the electricity to also travel the way you don't want it to go in the event of a nearby lightning strike. Sorry if this seems really stupid, but I'd only like to know if its possible however unlikely it is.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: AGP Bonding
    My neighbors telephone pole was hit by lighting. It dug a trench all the way to their hot tub. Everything plugged in was toast. Hot tub, fridge, tv's ect.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: AGP Bonding
    You will be fine. That is the idea of bonding in that everything in/around the pool is at the same potential to ground.
    Support the site
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,809
    Re: AGP Bonding
    In theory you are safer in a bonded pool than you would be standing on the ground. Were lightning to strike near the pool. You and everything around you in the pool share the same electrical potential and even though your voltage would get very high briefly no current would flow threw you. Now if your head was above water and you get hit with lightning first you would be toast. Listen to your mom and get out of the pool if you hear thunder and get indoors. Properly bond your pool to prevent the far more likely occurrence of a faulty circuit energizing the pool or surrounding area from hurting you.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2013
    Sacramento, CA
    2,769
    Re: AGP Bonding
    In a lighting strike the presence of the bonding system does not make the pool less safe. Whether you are injured by lighting (or any electricity for that matter) is largely a function of chance and the resistance paths around you. If lighting struck and energized the bonding system its doubtful you in the pool would be energized because unlike electricity us humans generate the electricity in a lighting bolt is attempting to go to ground. So only if you are in the direct path of the strike will you be struck. Some may enter the bonding system but that should all go to the least resistance area of the ground near you and will all dissipate within 50 to 100 feet of where it struck. There might be effects on electronics.
    You do raise another issue. Modern homes have numerous electronic components and systems. Cable TV and Telephone for example. These all need to be bonded and in most cases grounded. So there are more and more bonding and grounding systems in your home.
    One reason that pools use insulated equipment grounding conductors is so that in case of a failure they do not inadvertently energize the bonding system.
