Thread: New to forum
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    New to forum
    Hello everyone .. New to the forums and a new pool owner. As you can see in my sig, just built last September, ran for two weeks and closed. Opened up in late May. Had a little bit of algae but nothing crazy. The installer did a complimentary opening where they dumped in 5 gallons of liquid chlorine and started up the filter system.
    I am an avid do it yourselfer so I went right to work doing some research. I've been lurking on this sight for a while and after some research, I quickly ordered a Taylor K-2006 kit from Amazon. It's a nice little kit. I also added a Salinity test kit since I own a SWG.
    After baseline testing I basically needed everything. Once I established a chlorine level, I went after Cya first and then alkalinity followed by ph and then calcium hardness. I added 15lbs stabilizer, 25 lbs baking soda, 2 lbs Borax, and 50 lbs calcium chloride. My levels today are as follows:
    FC - 7
    CC - 0 (I've never had a reading yet)
    CYA- 80
    TA - 110
    PH - 7.5
    CH - 250
    Pool looks very good. I've been slowly working the FC down to target around a 6. I've also been watching the ph rise slowly so I can hit it with a little muriatic to bring the alkalinity down a little.
    I know I will have some questions as there is no way I can be this lucky on the first try .. Haha
    Looking forward to learning more as I go.
    22,000 gal Cardinal Oasis 36x18 IG Vinyl
    Pentair IC40 SWG Sand Filter 1 1/2Hp Superflo pump Single Speed 3450 RPM
    Build date 9/25/15
    Taylor K-2006 with Salinity
    City water for fill
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: New to forum
    Welcome to TFP!
    So as not to confuse folks, please list alkalinity in your test resllts as TA as that is what most folks are used to seeing.
    While a TA of 110 is OK by pool industry standards, many of us feel that is a little high. We find pH to be more stable with the TA around 70 or even a little lower. My pool likes 60.
    Support the site
    30,403
    Re: New to forum
    Welcome to the forum.
    Who says it's luck? Your post indicates a very good understanding of the basics that we teach....all the credit goes to you. You are on your way to a Troublefreepool! Nice work!
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    Re: New to forum
    Here it is at the end of last year
    Build date 9/25/15
    City water for fill
